Hi All,
Just happened to be checking all my lights tonight and noticed that there's only one rear fog light. I can't recall whether there were ever two (one in each tail light cluster) or was there ever only one.
I've tried searching online for pics of the rear tail light clusters all lit up, but have had no luck finding pictures which also have the rear fog light (or lights as the case may be) turned on.
The owner's manual is about as useful as t*ts on a bull in this respect.
Searched this forum and others, but have had no luck for the past hour or so.
So, here I am, asking to inconvenience a fellow CC owner to have a look at his/her CC's tail lights with the rear fogs turned on to confirm if there is only one fog lamp in the tail light cluster on the drivers side, or are there fog lamps in both tail light clusters?
I've attached a pic to help illustrate my query (Click to enlarge).
Thanks!!
PS. Not sure if the car is smart enough to let me know there is a fault with the rear fog lamp (or lamps as the case may be). There are no error messages on the MFD, nor have any fault lights appeared in the instrument panel area.
Thanks!!
