Cabin filter where and how to remove?
  • Cabin filter where and how to remove?
    Hi
    As above just wanting to check its condition.anyone got the info?
    cheers
    warrick
    sigpic2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
    Most likely in your passenger footwell. Have a look underneath behind the glovebox and there should be a couple of thumb screws. Undo them and try to rmove the panel and there should be a box in there. If its similar to the golf (which it most likley is) the bottom of the box should slide off and the filter will fall out. Be careful as it will be full of leaves and dirt and junk!
    this message thrown at you from the window of my flying Golf!
    MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
      thanks for that,worked a treat.all done and dusted.wasnt too bad but still gave it a good clean.
      cheers
      warrick
        You can get charcoal infused ones off ebay for relatively cheap. It helps prevent the mouldy sock smell the filter gets during humid weather!
          thanks i will check it out.
          cheers
          warrick
            well i ordered a pair of these from the states.only took 10days fit perfectly.
            cheers
            warrick
            2 Pack HQRP Charcoal Cabin AIR Filter Fits VW City Jetta Passat CC GTI Beetle | eBay
              Her warrick, thanks for the link, just bought a set. Have they kept the smells away?
              Sent from my LG-D802 using Tapatalk
                hi
                they have been fine ,worked a treat.
                cheers
