i did this today and it was really easy. i see in one of the other model threads they showed removing bumpers etc.i just got the old dremel out,ground off the tops of the plugs and knocked the remainder thru with a screwdriver. 10 minutes work max. i'm sure others have done this but when i searched it didnt come up. got some plastic push in plugs the same size as the sensors.will just paint them up and should be done. if you were really fussy you could countersink them into the bumper to make then even closer to the sensor look.
cheers
warrick
cheers
warrick
