When I have previously done some work underneath on the 2009 Passat CC 2.0L TDI I have had access to a pit (of sorts). Anyway, now I just want to do an oil change (have done several before with the pit) and so I thought I'd use my axle stands (which I use for my other vehicles) on the front end so I could get the car up enough to get underneath and drain the oil. [My other vehicles have a lot more ground clearance and you can even just crawl underneath at a pinch.]
Well, Passat CC owner's manual mentions the four jacking points, but not potential axle stand locations! With the provided wind-up jack at the triangle-marked location behind the front wheel, it is then impossible from what I can see to put an axle stand alongside it (the jacking sill is only c.10cm long). The provided jack doesn't even really raise the vehicle enough to get an axle stand underneath I don't think.
Am I missing something here? Haven't found any clear guides with photos and I don't want to damage the underside of the vehicle.
Hoping someone can help me out with this one.
