Electrical "Big 3" upgrade
  • Electrical "Big 3" upgrade
    Can anyone recommend an auto-electrician in Brisbane to do a "Big 3" upgrade?
    I could possibly DIY, but interested to know what the cost would be to have a professional do it.
    Basically it involves upgrading to larger power cables, ideally 1/0 AWG:
    - Battery negative to chassis/ground
    - Engine to chassis/ground
    - Alternator to battery positive
    The factory cables look pretty lightweight and I'm planning an audio system upgrade.
    Hopefully the Big 3 will also give the electrical system a boost and make the engine idle smoother etc.
    2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
