Crack in plastic sunroof surround
I just recently purchased a 2019 model and while I was looking mid last year I viewed a 2017 model with the same issue. The seller had an agreement from vw to replace under warranty, however part had to come from Overseas. I had seen the service paper that stated it would be replaced under warranty.
The seller mentioned that vw knew of a fault where screws on that part were over tightened on the 2017 model and the flex of the car can cause that part to crack. The car I viewed the crack was in the same place.
Thanks for that insight, there doesn’t appear to be many reported cases online.Originally posted by messy_smith View PostI just recently purchased a 2019 model and while I was looking mid last year I viewed a 2017 model with the same issue. The seller had an agreement from vw to replace under warranty, however part had to come from Overseas. I had seen the service paper that stated it would be replaced under warranty.
Mines a early 2018, seems that some of them are affected also.
The dealer’s had a quick look at it but will be starting the warranty process tomrorow, so I’ll post updates on how all of that goes.
That’s a shame but it’s good they are fixing it. I’m hoping it last this time around [emoji4]Originally posted by messy_smith View PostHi Rjt86. seems my MY19 suffered the same failure. cracked formed same place as yours, dealer said VW will cover under warranty. unfortunately they wont replace the paint protect film that is on that section as they view this as a modification, bit crumby but glad it was a no fuss exercise.
I noticed this on my 2019MY yesterday; booked in to VW - very cold weather recently with several sub-zero nights in a row. Exact same position for me and actually have identical cracks on both sides. Can't upload images for some reason.
I also get the large 'twang' when pulling off the drive - this will also be investigated when it goes in...I was told 18 months ago that they had the fix for this and were waiting something out of Germany but I think this was to fob me off for a bit longer to whittle the warranty down.
I would still take Arteon [emoji4]Originally posted by REK View PostThis is scary considering my Arteon is out of warranty now :|
Sent from my SM-G986B using Tapatalk2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
Seems I spoke too soon. VW is inspecting the vehicle roof again and lots of questions about the car history. i had a cracked windscreen a few weeks later and they are trying to tie that to the crack or the strip of ppt film that is on the leasing edge of the sunroof plastic part. Implying it isnt a known fault but something else.
hopefully I they come to the party on it.
Do you know if that's a complicated (or expensive) part?
I'm kinda toying around with the idea of making one out of carbon fiber... wondering if it's feasible to make a mould from an original2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
Interesting... so you'd probably need to buy a new one to create a female mould from. Could get the contour while in place, but wouldn't get the depth/edges right. If it's glued in place, then the back may not have clips/details to worry about.Originally posted by messy_smith View PostSorry, not sure of the cost of the part. it looks to be about 1cm thick. if you can match the curve at the front you could replicate. the original cannot be taken off without destroying it. glued in place and the repair diagram i have shows they need to cut into it to remove.2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
