I've confirmed this tweak is working
stolen from A guide to enable EU specific features for AU Spec Tiguans
1. Module 5F
Adaptations
Car_Function_List_BAP_Gen2 traffic_sign_recognition_0x21
Set to Active
Car_Function_Adaptations_Gen2-menu menu_display_road_sign_identification
Set to Enabled
Then go to Coding
Long Coding
Byte 24, activate Bit 6
2. Module A5
Then go to Coding
Long Coding
Byte 16, activate Bit 4
3. Module 17
Then go to Coding
Long Coding
Byte 5, activate Bit 2
Then you need to disable Road Sign Fusion.
4. Module A5
Adaptation
Road sign detection fusion mode
Change from Road sign fusion to Road sign detection
If you have HUD in your Tiguan, the following coding will enable speed signs to be shown on it (For NZ and other countries)
Module 82
Coding
Long Coding
Byte 0, Activate Bit 0.
Reboot the infotainment system.
1. Module 5F
Adaptations
Set to Active
Set to Enabled
Then go to Coding
Long Coding
2. Module A5
Then go to Coding
Long Coding
3. Module 17
Then go to Coding
Long Coding
4. Module A5
Adaptation
Module 82
Coding
Long Coding
