Replacement Battery 2009 T2 V6TDI
  • Replacement Battery 2009 T2 V6TDI
    Hi Guys,
    Anyone replaced the original T2 Treg battery with an AGM type? and can you do it without scanning the Q codes into VCDS? Are settings in VCDS necessary when you replace the battery?
    Thanks, Gus
    2009 V6 TDI....Marvellous....
    Replacement T2 Battery
    Just another perhaps dumb question re the replacement battery for the 2009 T2 V6TDI with an AGM type. They need a slightly lower charge voltage from what I have read, wondering if that has an effect on them. I use AGM's in my boat and that appears to have a standard charge voltage on them when the engine is running, and they have lasted for years - way longer than any wet deep cycles ever did......
    Gus
    Originally posted by biggus View Post
    Hi Guys,
    Thanks, Gus
