Hi all, my touareg has just turned 6 months old - I got a 6 month service reminder from the dealer today. I have only done 5000km and was working on the assumption of a 12 month service interval. Does anyone recommend a 6 month service and an estimate on cost? Thanks mike
Touareg 6 month service?
The factory service interval, as determined by the manufacturer, is 15 000 km or 12 months, whichever is reached first.
Some dealers, workshops, garages or mechanics (whether they are franchised or independent) may recommend or suggest more frequent service intervals. Whether such work is to be carried out is entirely up to the owner.
Consequently, cost depends entirely on who does it, and what they do or don't do.
As with all work, always ask for a quote beforehand, and ask precisely what is to be done.
Originally posted by Mikestreg View PostHi all, my touareg has just turned 6 months old - I got a 6 month service reminder from the dealer today. I have only done 5000km and was working on the assumption of a 12 month service interval. Does anyone recommend a 6 month service and an estimate on cost? Thanks mike
From what you've posted I would definitely get the engine oil and the oil filter changed. Besides, it could be already 12 months old, check the production date on your Touareg.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
It's not so much the distance travelled per se, but more the nature of the journey.
At one extreme, if the 5 000 km travelled so far was done in a single journey, then the case for changing the oil is not strong.
At the other extreme, if the 5 000 km travelled so far consisted of 5 000 cold start journeys of 1 km each, then the case for changing the oil is stronger.
Given that a six month interval is not part of the scheduled service regime, it will require a judgement call from the owner.
If you stop engine for 5 months after you've done 5,000km, I would be worried about the rust on the cylinder walls and what happen to the oil after all that rust is scraped by the piton rings when you start up and the oil wash it into the oil sump. Either the way under such condition if you change the oil or not it's still not good for the engine.
The bottom line is, the oil and the filter is cheap (probably amongst the cheapest parts in the Touareg), the engine isn't.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostIf you stop engine for 5 months after you've done 5,000km, I would be worried about the rust on the cylinder walls and what happen to the oil after all that rust is scraped by the piton rings when you start up and the oil wash it into the oil sump. Either the way under such condition if you change the oil or not it's still not good for the engine.
Originally posted by Transporter View PostThe bottom line is, the oil and the filter is cheap (probably amongst the cheapest parts in the Touareg), the engine isn't.
Generally speaking, halving the manufacturer's recommended service interval on principle is not something I personally adhere to. If it were me, I would try to service the vehicle according to its needs:
If a x km service interval is justified, then the vehicle should be serviced every x km.
If a 3 000 km service interval is justified, then the vehicle should be serviced every 3 000 km.
If a 30 000 km service interval is justified, then the vehicle should be serviced every 30 000 km.
OP: ball is in your court.
Originally posted by Diesel_vert View PostIf it is determined that internal parts of the engine are rusting so quickly and to such an extent as to cause severe wear and a drastically reduced expected service life, then the oil's condition would indeed be the lesser concern in this scenario.
While it is true that the relative cost of consumables is low compared to the purchase price of the vehicle, it doesn't necessarily follow that the vehicle should be serviced more frequently (or less frequently) than is required.
VW Audi Oil Sludge Class Action Settlement
I know you may say that it's a different market, different oils, fuels and so on, but still they didn't get the servicing intervals right - they were .... WRONG, and it wasn't the first time. Oh, and how wrong they got the NO maintenance on the auto transmissions in the T5s it's a very good example how easily the engineers can be wrong, costing the T5 owners $10,000+ in repairs.
And since the excessive oil sludge problem is repeating in every decade, I rather change the oil more, since I can't change my cars every 3-4 years.Last edited by Transporter; 02-05-2014, 05:54 PM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostI guess the same people who told you to service your car once every x amount of km got themselves in the trouble (not for the first time though)
In regards to the class action, it was raised because certain models in the North American market were forming oil sludge and coking deposits in the engine despite being maintained as recommended by Audi of America (AoA) and Volkswagen of America (VWoA).
At the time, AoA and VWoA did not explicitly specify that only engine oil which complies with VW oil standard 502.00 should be used for those affected models.
The class action was settled with AoA and VWoA being required to pay 100% for damages related to oil sludge (past and present), extend the warranty to 120 000 miles (190 000 km) or 10 years, receive a $25 discount off the price of an oil and filter change at a dealer, and provide instructions for the owner to only use engine oils which comply with VW oil standard 502.00, a list of which is maintained on their respective websites.
No changes were made to the service interval for those affected vehicles.
The service interval for passenger vehicles in the U.S. market is 10 000 miles (16 000 km) or 12 months, whichever is reached first.
I live in Canberra. Relative extremes of hot and cold.
I pay to change engine oil and filter in June and November, as a minimum, for my three vehicles. Don't care how far I've gone.
It pays to read the manual and understand what the dealer or indie, will do on a 'service'.
Cheers,
StuMY07 V10 TDi Touareg
98,000 Km
HPF flash tune - 273 rwkW & 813 Nm
And I doubt that it would happen in a petrol engine. Lots of North Americans lay their cars up for five months or longer without issues.Last edited by V10Touareg; 17-07-2016, 06:18 PM.MY07 V10 TDi Touareg
98,000 Km
