Have just got a price of $2400 to remap the ECU in my coming V6 Turbo Diesel by Oettinger--has anyone done it and if so was it worth it?Rgds Sparky
Oettinger Turbo Diesel Remap
Would not recommend remapping the factory ECU, it could screw up the ability to report error codes correctly.
A better way would be to used the DP Chip plug and play solution from AWD Technologies. If you are getting the V6 Tdi the DP31 literally installs in 5 minutes and makes a remarkable difference to the of the line performance.
I would recommend you visit this web site and research the product for your self.
Plug & Play DPCHIP, get up to 35% more power and torque! Up to 10% better fuel economy! 6 year warranty, 60 days money back guarantee! plug-in power for all EFI diesel engines....
Treg2
oettinger
Offered by Volkspower via Ottinger download..apparently okd by my local dealer--see Ottinger site re the results...191KW and 550nm--the DP loom as I understand it generally increases fuel pressure ...understand the Ottinger and Steinbauer systems change a number of variables--hence my question who has tried any?
Originally posted by Treg2 View PostWould not recommend remapping the factory ECU, it could screw up the ability to report error codes correctly.
Treg2
Plug in chipping isn't as sophisticated as flashing the std ECU. It modifies signals between the ECU and fuel system rather than using correctly written software in the first place.
Chipping or Remapping is governed by what type of engine configuration and what modifications you have performed.
I have just traded an MY03 Subaru WRX with cold air induction, exhaust, fuel pump and injector modifications which required a ECU remap.
My newly purchased Touareg has none and most likely will never have any modifications to the engine so remapping the ECU seems unnecessary particularly when Volkswagen Australia most likely would NOT warranty such a modification.
My own personal decision was to use the DP plug in option mainly because a large number of diesel transport vehicles are using it successfully. It is undetectable by the dealers software if I choose to leave it connected, but if I do want to remove it I can pull it out in 5 minutes and revert the vehicle back to factory spec.
As for the error code comment I was speaking from experience, but I must admit it was with my WRX which is a whole different animal to the diesel powered Touareg.
I suppose the bottom line is do what ever you feel comfortable with, perform due diligence to confirm who is going to warranty your engine if something goes wrong or be prepared to cope the cost yourself.
Treg2
Chip it or not?
If you have a chip installed Vag-com will find out, so I thing the factory VAS diagnostic tool will find it even faster. And if you reprogram it, it will be recorded similarly like in this attached picture.
I personally like original things - not modified.
Put yourself in the manufacturer shoes and imagine that somebody bought your car which you designed and produced. He modified it to get more power out of it with out proper testing and when it is broken down he even demands repair it under the warranty.
Would you repair it?
I wouldn’t.
The manufacturers warranty is the best warranty you can have. Don’t fell for warranty from the chip manufacturer. Wait till the warranty is over and then chip it.
MRL T5Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Just to clear up some of the "myth's" in this thread:
A properly tuned ECU reflash (like Oettingers) is exactly that - a fully retuned ECU, changing requested & actual boost, fuel delivery, timing / pulse, load signals (yes -- the load signals that feed directly to the TCU & also take the feedback from the TCU - which protect your transmission). It also transmitss all sensors in their exact, original form, fault codes & all. if your fuel pressure sender gets a fault - its recorded!
A "tuning box" of any brand can not do all this - pure & simple. We sold "tuning boxes" from Germany for many years (and the German ones were about 2k) - We have seen some sold here in Australia in volumes that are made in Indonesia for about a total cost of $75 and then sold on for $1000 to $1500. Tuning boxes were good in the older style motors, but would you use them on a newer style motor? - If you know how your EDC 15 & EDC 16 ECU works in your later VW, you will know how it records & logs data. Bump up the fuel pressure & it records it - purely & simply.
There was a well known case of a Touareg V10 TDI in Brisbane that was fitted with "Tuning Boxes" - the car developed fuel system leaks (lots of them) and was taken in for "warranty" - Of course it was denied and upon investigation it was found that the owner had removed the tuning boxes as advised by the "company" that sold them to him.
Big risk on an expensive new TDI motor.
Of course we sell Oettinger so we know it's effects - and also what written warranty is offered from them (see the website) - and we can also arrange for Oettinger to be installed in your new Touareg via select dealers around the country - complete with 3 year written engine / drivetrain. Feel free to call me if you need any more details. We are responsible for tuning well over 500 VW & Audi diesels in the past few years (07 3392 2980)
Guy
P.S. - MR T5 is correct -
Modifications of any sort - Can effect warranty.
The biggest issue & responsible for the biggest number of claims is window tinting - Most people think window tinting is harmless - but often an untrained apprentice will have the job of dismantling your new cars door trims to get access to the windows - Broken clips, rattles, damaged door handle connectors etc.
So tinting your windows can void the warranty on the doors of your car (and has!)
To replace that broken clip in the door trim the worst thing can happen I pay for the clip and an hour of the labor and I can pay for it with the smile on my face.
But if the dealer would be saying to you after your Touareg was brought to the workshop on the tow truck: Mr. Guy_H you modified EDC module which caused damage to the engine and it will cost you $15,000 and it will take a month because the parts we need have to come from Germany. I want to see the same smile on your face.
P.S
You see some things are just not worth it.
It is very competitive market and manufacturers are tuning their engines for more and more power all the time.
Maybe you should give them your number; because they might be interested in your power chips and performance modifications that you are selling in hundreds.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by MRL T5 View PostLet me tell you something. If I go to the dealer to replace broken clip and warranty would be voided because of the window tint:
P.S
cheers, aydan'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Originally posted by gldgti View Postplease lets not make inflamatory statements. it is not in the interest of healthy discussion - thanks.
cheers, aydan
The tinted window - broken clip voided warranty or the modified EDC broken engine voided warranty.
That's raising awareness of potential danger that you may lose a new car warranty which you paid for. And doing more harm than good. Leaving the legal issue alone.
I know that on this forum is many people who modify their cars and maybe they see it from different point of view.
I don’t like when somebody is using my post and try to make an idiot from me
(P.S. - MR T5 is correct -
The biggest issue & responsible for the biggest number of claims is window tinting).Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Oettinger Remap
As the one who started this discussion,its interesting that VW themselves have just remapped the 2008 TDI from week 45 production in 2007 from 165kw and 500nm to 176kw and 550nm....I also agree with Guy H that from my research the O system is the most appropriate way of adjusting performance..it is not warranted by VW but understand they will at least fund it in their finance packages so I am told!Rgds Sparky
Also understand that in the normal course the IS NOT visable during Service!
