Hi! I want to power a UHF radio andTyre pressure sensor....are there any easy power connections available rather that the 12v Cigarette plugs or off the battery direct under the passenger seat?? Rgds
Easy electrical connection?
Go direct into the fuze boxes located each side of the dash (End of dash when door is opened).
Several locations are "spare" which will allow permanent power or ignition on power. I don't have a location diagram handy but working with your multimeter at spare slots you should find your way around.
If this photo worked you will see what i did for a bluetooth, look at the red wire in the lower left row.Flipper Dog
Now - T-Roc R, Audi Q5
