Originally posted by robrut
View Post
1 of 2
2 of 2
Spare wheel / snorkel
This is a sticky topic.
Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by robrut View PostI own a 2005 TDI. At the time of purchase in early 2006, I was not prepared to wait for a factory fitted rear wheel carrier.
I have bitten the bullet, and bought a spare wheel & tyre, which I carry on a roof rack when on trips away.
However, I want now to buy a rear wheel carrier.
VW do not sell them as an accessory. Kaymar does not make one for a Treg.
Any ideas, anyone?
My location is Gold Coast.
Robrut
When I bought my new V6TDI this year I intentionally bought a spare wheel, not the rear carrier as I felt the inconvenience of moving the carrier to open the rear door would annoying. Also, I don't like the look of the rear carrier. I'm intending to make up a false floor to go over the spare when laid flat. However, seeing you have been carrying a spare around with you, I'm interested in why you would now want a rear carrier? Cheers GeoffT Rex
2008 T2 V6 TDI Atacama/Anthracite, Air Susp, Bi Xenons, Sunroof, Fogs, Roof Rails, Tow pack, full size spare inside car
Harks,
Be careful that you don't buy the wrong wheel! You have said you have a "TDI", but not which engine... If you have a V6, it is - as Houso says, a 5 x 130 bolt pattern. However, if you have an R5, it is a 5 x 120! T5 Transporter wheels will fit an R5, and so there may actually be a "cheap" steel wheel option - even in 16"...
Robrut & Harks,
You cannot retrofit a genuine spare wheel carrier, it is a major factory job integral with manufacture. There are differences in sub-frame (extension to hinge area for strength), bumper (now houses numberplate and slot for weight-carrying tab at bottom of wheel carrier), tailgate, etc. Also it is integrated in the central locking, has number plate lights mounted on it, display on dash when open etc.
Trex,
As for why anyone would want a carrier, I guess it is personal preference but I actually like the look of the carrier (must be the inner engineer), and felt the inconvenience of driving a long distance on the temporary tyre (and where do you put the flat one when you are fully loaded?) or the inconvenience of a large section of the boot taken up by a potentially muddy tyre or the inconvenience of wrecking my back trying to get a spare on or off the roof or the inconvenience of buying extra fuel and worse handling with a heavy wheel on the roof were worse than the inconvenience of swinging the carrier open to lift the tailgate.
cheers..Neil
Audi Q5 2.0 TDI
sold and missed: '05 Touareg R5TDI
SWMBO: '08 Golf Pacific TDI DSG
Neil
You are right - it is personal preference. There is no perfect solution. My last 4WD was a Prado and on upward slopes my wife found she could not use the rear door as the weight of the wheel would push the door open quite violently. Also opening the rear door in parking lots can be dicey if another vehicle is close.
At least with either solution we can enjoy our Tregs on the open road without relying on the ridiculous space saver! Cheers.. GeoffT Rex
Alternative Spare Wheel Mount
I normally just carry my spare wheel on the floor but at times I need the floor space for other objects - such as a dog. So I got to thinking about alternative locations and remembered my old Range Rover had its spare located upright against the nearside rear window.
I tried standing my new spare in that location and although it looked an unlikely fit, it was possible to close the rear hatch without interference as long as the rear cover and cargo barrier are removed. So I have welded myself up a frame which I simply zip tie to the floor location points when I want to carry the spare upright. There is approx 12mm clearance all round.
The pics tell the story. It actually looks quite neat if you put a generic cover over the tyre. BTW this is the new Scorpion ATR in 245/65/17.
GeoffT Rex
Originally posted by T Rex View PostI normally just carry my spare wheel on the floor but at times I need the floor space for other objects - such as a dog. So I got to thinking about alternative locations and remembered my old Range Rover had its spare located upright against the nearside rear window.
Geoff
It is really nice improvement I saved your pictures to my folder (thank you) and will make that my summer holiday project. It would be nice if you include the measurement.
How would it be on the right side? I mean the rear view visibility.
Once again, thanks.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Geoff,
What a neat solution - looks great and minimises the floor / load height issues. Keep us posted on the performance of the scorpions.
cheers,
..Neil..Neil
Audi Q5 2.0 TDI
Specs for wheel holder
Thanks for the feedback guys.
The attached pic should help. Critical dimensions are the vertical & lateral location of the nut (welded in position) relative to the base as this locates the tyre so there is clearance all round (it rests on the base). You may need to do a trial fit, especially if you have different wheels or tyres.
Holes are drilled through the side of the base to allow zip ties to the cargo tie down points. It is surprisingly secure once the tyre is in place. Make sure you carry something to cut the zip ties or else you cannot access under the rear floor
Reverse the posiion of the upright for R/H installation but be aware access to the CD player will be difficult in that location.
I won't be replacing my other four P ZERO tyres with the ATRs until I need to go in the rough stuff (or they wear out) but I'll let you know when that happens.
GeoffLast edited by T Rex; 10-12-2008, 03:12 PM.T Rex
Hi,
I'm new to this site; we purchased a V6 TDI in November and are enjoying driving it very much. We did a 4WD course a couple of weekends ago which was fantastic. It was great to see what we could do in the car. We'd like to purchase a spare tyre to throw in our camper trailer when we go off road but the $600 VW fee turns us off (have read previous posts with the same issue. )
We're in Melbourne; any suggestions as to where we can source a cheapy? (17in standard)
On another issue, does a Touareg snorkel exist in Australia? We got a bit of a scare when two lights came on after a water crossing.
Thanks,
Fiona
Thanks,
Fiona
Yeah, and welcome to the forum.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Thanks,
Fiona
Hi Fiona,
just keep looking on Ebay and you will see the 17" rims pop up now and then.
Reference lights coming on with your water crossing, which two light were they?Flipper Dog
Now - T-Roc R, Audi Q5
Never seen a snorkel although the question's been asked a million times. I figure just don't go too deep. I'd been interested in what lights came on as well. Never had a problem myself and I've had water over the bonnet, well bow wave anyway2009 LR D3 SE
2005 Touareg R5 Lux - gone
spare wheel
fiona,
i had a concern with the original spare, before going on holiday i purchased a cheap steel VW rim (under $200) from barloworld in moorabin and got a tyre fitted.
glad i did as i ruined a tyre off road 600km from home, threw the spare on and drive home towing.
when you get the crazy $600 price they are refering to an original mag
also the standard spare is tedious to fit and inflate
moosemanmooseman, 2007 touareg, assorted, bikes, boats ect
Welcome fiona and mooseman!
Mr Moose - what touareg variant do you have? An R5 TDI?
If so, then I can understand your ability to fit a "cheap steel VW rim". What size was it and what tyre did you get fitted?
(I've never heard of a dealer making that option available, although the Touareg 360 project vehicles from Germany were R5's with 16 inch steel rims = supposedly they match the transporter...)
If that is the case (ie you have an R5), then your experience is unlikely to be available to others with V6 or bigger engines as they have bigger brakes and also a different bolt pattern.
However, if you have a V6 etc, with the 130mm bolt pattern, then you did VERY WELL getting a cheap wheel from VW. I don't think anyone else has come across that?!?
Please comment...
Also, Fiona, were the two lights that came on during the water crossing on the centre of the dash past the flip-up storage box? If so, that is not unusual. They will almost always come on during a water crossing telling you that the front parking sensors have got water in them and will not work for a few minutes. Otherwise, what were the lights and we can see if the brains trust here can comment.
cheers,Last edited by Moonan; 12-02-2009, 11:11 PM...Neil
Audi Q5 2.0 TDI
Test Slow
