Touareg 7L 6D Trunk Elec - Electric trunk not closing using the close switch
  • Touareg 7L 6D Trunk Elec - Electric trunk not closing using the close switch
    Hello All,
    My Touareg 7L has developed a issue hoping someone here would know where to look to try and fix it.
    The Issue
    The Boot lid(Trunk) opens fine electronically using the driver door button and remote etc.
    Once open, it will not close using the close button (F206) located at the bottom of the boot lid.
    The close button used to work fine, it just stopped working one day.
    Minor annoyance, I have to manually push the boot lid closed and it locks fine.
    Troubleshooting I've done
    1. I have checked the wires(continuity test) and all 4 wires are fine from the button all the way to the lid control module hidden at the bottom left corner of the car.
    2. Thinking it was the button itself, I replaced it with another one.
    3. Using VCDS I can see the button activating when pressed.
    4. Done the VCDS test for the 6D trunk elect. and the boot lid activates in both directions electronically (Open and Close) without any issue.
    5. Done Basic settings as per instructions here. Didn't solve the problem.
    All the above, leads me to think it is some sort of software setting issue. But what?
    I have a tow bar fitted although I doubt it has anything to do with it. It used to work fine until few months ago.
    Below is a screen shot of the 6D Electric Trunk settings in VCDS.
    Any suggestions ?
    Has anyone got a 7L Touareg? What is your setting like?
    Thanks.
    Having a trailer usually prevents the boot opening remotely so as you dont whack anything on the towbar have to be careful with bikeracks etc as well
      Not sure if this will help, but here is a controller map of the 7P Touareg 6D module, I think Hillbilly is on the right track, look over the advance measuring values and see if some value may be blocking the function (like trailer detected)
      Code:
      ;SW:7P6-959-107-C   HW:7P6-959-107 ---  Trunk Elect.
      ;Component:HDSG-Modul    H10 0043 Coding:0533314003
      ;EV_HeckkTouar202142EV_HeckkTouar.rod
      ;Tuesday9May2023
      ;VCDS Version: Release 23.3.1 (x64)  Data version: 20230421 DS346.2
      ;VCID: BFD0AD2AC7FAB9D2B61-80EA
      GroupDescriptionActual
      IDE00002Transport modenot active
      IDE00019Voltage terminal 3011.66 V
      IDE00030Status of actuator testnot active
      IDE00075Vehicle speed0 km/h
      IDE00102Control Module temperature14 °C
      IDE00301Mileage121286 km
      IDE00310Outside temperature13 °C
      IDE00320Consistency of EEPROM dataValid EEPROM Data
      IDE00322Status of basic settingnot active
      IDE00325Diagnostic modeVW - diagnostic mode
      IDE00798Number of possible access authorizations2
      IDE01231Terminal 30 voltage for actuators11.66 V
      IDE01846Static current shut-off stageDeactivation stage 0
      IDE01990-MAS01870Pressing a button-Button for rear lid unlocking in rear lidNot operated
      IDE01990-MAS01871Pressing a button-Rear lid lock button in luggage compartmentNot operated
      IDE01990-MAS01872Pressing a button-Rear lid remote control lock switchNot operated
      IDE01990-MAS01873Pressing a button-Rear lid unlock button in remote keyNot operated
      IDE01991Motor 1 for tailgate: statusnot active
      IDE02010Motor 1 for rear lid: activation0 %
      IDE02011Motor 1 for tailgate: current0 A
      IDE02012Motor 2 for tailgate: statusnot active
      IDE02013Motor 2 for rear lid: activation0 %
      IDE02014Motor 2 for tailgate: current0 A
      IDE02017Rear lid position: relative0 %
      IDE02018Rear lid position: absolute32
      IDE02019Position programmable opening stop99 %
      IDE02020Learned open end position667
      IDE02049Trailer detectednot detected
      IDE02068-MAS00106Time stamp-Year23
      IDE02068-MAS00107Time stamp-Month5
      IDE02068-MAS00108Time stamp-Day9
      IDE02068-MAS00109Time stamp-Hours20
      IDE02068-MAS00110Time stamp-Minutes43
      IDE02068-MAS00111Time stamp-Seconds6
      IDE02072Pitch angle1 °
      IDE02073Roll angle5 °
      IDE02075Play protection time-out time10 s
      IDE02077Remaining run time for play protection0 s
      IDE02078Activations of rear lid closing button7481
      IDE02079Activations of rear lid unlocking button7044
      IDE02080Activations of rear lid remote unlocking switch434
      IDE02081Activation of remote key button rid lid opening405
      IDE02082Opening cycle counter7407
      IDE02083Closing cycle counter7400
      IDE02084Counter obstruction detected306
      IDE02085Counter of selectable opening stop adapted1
      IDE02086Play protection counter active0
      IDE02087Counter for function limitation due to insufficient voltage0
      IDE02088Counter for function limitation due to excessive voltage0
      IDE02089Counter for lock or closing assist implausible353
      IDE02090Counter for function limitation due to excessive temperature0
      IDE02091Counter for terminal 30 reset8
      IDE02092Tailgate conditionlocked
      IDE02093-MAS01943Status of rear lid lock-Terminal 1closed
      IDE02093-MAS01944Status of rear lid lock-Terminal 2closed
      IDE02094Status of closing assistretracted
      IDE02095-MAS01947Status of pinch protection-Clamping strip 1No obstacle
      IDE02095-MAS01948Status of pinch protection-Clamping strip 2No obstacle
      IDE02095-MAS01949Status of pinch protection-Clamping strip 3Malfunction
      IDE02095-MAS01950Status of pinch protection-Clamping strip 4Malfunction
      IDE02096Warning soundOFF
      IDE02097Position Sensor 132
      IDE02098Position sensor 232
      IDE02100Status sensor 1OK
      IDE02101Status Sensor 2OK
      IDE02102Motor 1 for rear lid: voltage1.87 V
      IDE02103Motor 2 for rear lid: voltage1.87 V
      IDE02171-MAS01913Terminals for closing assist-Closing assistancenot installed
      IDE02171-MAS01943Terminals for closing assist-Terminal 1not installed
      IDE02171-MAS01944Terminals for closing assist-Terminal 2not installed
      IDE02174Counter of flap opening angle basic settings1
      IDE02775Status of basic setting dataBasic setting performed successfully
      IDE03215Engine start using start-stop functionnot active
      IDE03421-MAS02684Hall sensors for position detection-Motor in rear lid control module: sensor 1Not operated
      IDE03421-MAS02685Hall sensors for position detection-Motor in rear lid control module: sensor 2Not operated
      IDE03421-MAS02686Hall sensors for position detection-Motor 2 in rear lid: sensor 1Not operated
      IDE03421-MAS02687Hall sensors for position detection-Motor 2 in rear lid: sensor 2Not operated
      IDE03422-MAS01947Pinch protection voltages-Clamping strip 14.53 V
      IDE03422-MAS01948Pinch protection voltages-Clamping strip 24.55 V
      IDE03422-MAS01949Pinch protection voltages-Clamping strip 30.61 V
      IDE03422-MAS01950Pinch protection voltages-Clamping strip 40.53 V
      IDE03773Counter for emerg. run. ops. because closing pos. not reached0
      IDE03774Counter for closing operations canceled by lock-up3639
      IDE03908Warning tone: output voltage0 V
      IDE03909Pitch angle incline sensor: voltage0 V
      IDE03910Roll angle incline sensor: voltage0 V
      IDE04718Motor 1 for rear lid: RPM0 /min
      IDE04719Motor 2 for rear lid: RPM0 /min
      IDE05101Number of activations to play protection active20
      IDE05229Reason for cancellation of rear lid procedurecompleted successfully
      Elapsed Time: 00:06
        Thanks for the replies.
        I will check and compare the values. I have a bike rack that I connect to the car now and then, it may be playing up with the close function.
          Code:
          ;Tuesday9May2023
          Elapsed Time: 00:06
          Greatly explained
