Hi All. This is a bit weird. We noticed that the rear DS door was not locking (09 Tig).
I investigated - manually locked it by flicking the lock mechanism with the door open. The door would not unlock using the exterior handle - only the interior. I have since managed to get it locked somehow, however it doesn't unlock with the key.
At about the same time the window regulator on the same door started playing up. It winds up around 2/3 of the way then turns around and starts going back down. You can get it to go most of the way up but it leaves about a 6 mm gap.
Any idea on the issue(s). It seems strange that I have 2 faults on the same door.
