Yes I had a leak on my 2011 125TSI which I got sorted under warranty. From memory I think it was seals on the water pump. But reality it could be anything causing your leak. Coolant is a closed system so you really should not be losing any - unless of course you have a leak somewhere. Take a look underneath for any tell-tale pink crystals.
There are products you can put into your coolant to fill small holes (stop leak), however they end up gumming up your whole system so I wouldn't recommend going down this path if you can avoid it. It's the lazy mechanics way of solving the problem.
