engine fault code 09571 boost control sensor
  • engine fault code 09571 boost control sensor
    car : 09 tiguan tdi
    ive been getting the glow plug light coming on a few times and took it to the local mechanic.
    scan came up with 09571 boost control sensor.
    they said it was the turbo boost position sensor is faulty and it will be approx 900 bucks to replace include labour.
    does that sound correct? could it be something else? am i still able to drive it for a bit?
    this car has caused me so much grief...
    Sounds a bit expensive for a sensor... Have you tried getting another quote?
      Is it a common rail tdi or the older PD tdi engine?
      DARKHORSE DEVELOPMENTS
      BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
      BRISBANE/GOLDCOAST/IPSWICH
      www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
        It should be common rail.
        Numerous Mk1 Golf diesels
          If its common rail then the boost control sensor is part of the turbo wastegate. They loose vac pressure internally so they dont move. A lot if the cost involved is labour and basic settings adjustment of the wastegate after the install.
            the mechanic told me that around half the cost is the sensor itself, the other half is the labour.
            he has told me hes done quite a few of these as it seems to be a common issue.
            does anyone know if this could possibly a solution? some repair kit?
            Turbocharger Boost Control Position Sensor - Skoda Octavia II (2004 - 2013) - BRISKODA.net
            maybe more info here
