DRL's on the Tiguan
Looks good but now you need some blue/white bulbs for the main headlights to match.
Did you do the install yourself?
I replaced the driving lights with led's and the low/high beams with Osram Rally bulbs to get a whiter and stronger light output.
The led's throw a fault code though
Hi, Ian,Originally posted by ian View Postyes I did it this morning had to find the place to run the power from the fuse box ,there's a removable cover behind the motor near the foot brake .Those headlights are actually the driving lights,
The front turn signal lights are DRL or I´m seeing wrong?
So, Those headlights are actually the driving lights and the day time driving lights are the ones that you can see...
I think i'm as confused as TigBR !
