Replacing Rear Light Lens 2012 Model
  • Replacing Rear Light Lens 2012 Model
    I have a crack in the lens and have found replacement on Ebay for $188 but I cant see any screws or way to remove and replace ...not like an old car where you get out the philips and replace in 5 mins it seems...
    Is it as hard as it looks ( ie impossible without an engineering degree)?
    The whole tail light assembly bolts from the inside... There should be an access panel of some sort inside the rear hatch or cargo compartment..
    - Anthony
    VW Tiguan 110TSI Life | Tungsten Silver
      To be clear, you replace the whole lamp assembly and lens, they are welded together to stop water entry. 2 or 3 torq screws holding it.
      The original VWA ones from memory were only $200 or $220 for my 2009.
      Subsequently I noticed at Volkspower they had cheaper grey-market imports than VWA.
      Do your ring around
      TDI tiguan in the drive. ParkAssist, comfort, fogs
      Service every 15,000, new fault code every 7,500km
        Have a look in your owner's manual under replacing bulbs. You will require a Torx T20 or T25 screwdriver to remove I think 2 screws by the hatch opening and one behind the first aid or jack stowage panel. 5 min job!
        MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
        Mods: VCDS tweaks |
