1 of 2
2 of 2
Tiguan Carbon Fibre Hood
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build ThreadTags: None
Well the Tiguan bonnet is extremely heavy so it would be a good starting point.
Not sure why they decided to put the hood there other than maybe to push air back to cool down the turbo?
However alibaba usually require you to buy in bulk and shipping on this is going to be a killer.
Also carbon fibre panels are a bit sketchy with ADR compliance.
You would likely do better ditching the spare tyre and all the impact reduction bars (giant metal beam behind the bumpers etc)
I'm not sure it's going to have a massive effect on performance with weight saving. Looks wise I prefer to be a it more discrete so if I was to change the bonnet it would be without a scoop.
I'm usually wary of buying aftermarket parts from China. Most Carbon parts are really just fibreglass with a few layers of CF for looks.
When I was heavily modifying my old Evos, I'd often get parts from Japan. They cost more but there was real R&D employed in the design and the build quality was top notch. I used to run a full Test and Service bodykit and CF bonnet with a CWest wing. The downforce through corners in Sepang and high speed stability was very noticeable.
Ps with lightweight CF bonnets, I found I needed bonnet pins to hold down the bonnet when traveling at high speeds.
The bonnet would need to be ADR compliant (and generally tested) to qualify - which would make 99.99% illegal. This will generally relate to pedestrian safety. Could cause an insurance risk as well, even if you're not worried about a possible defect.
Agreed on the bonnet scoop as well - unless you want a WRX/Forester Turbo look.
Bit of a link here to the SA regs, that's the easy bit.. it's the ADRs that are a fail:
sa.gov.au - Aftermarket components
Originally posted by team_v View PostWell the Tiguan bonnet is extremely heavy so it would be a good starting point.
I like the hood scoop designOk may be I like WRX look haha! If I fit this in to the car it will be more like a big mini cooper S.
Last edited by Ramee; 15-04-2014, 11:52 AM.2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
According to VicRoads CF hoods are not approved.. So this looks like a no go2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Tiguan CF lip spoiler
Anyone interested on these ..
Carbon Fiber Front LIP Spoiler FIT FOR VW Tiguan Standard Bumper NON R 2012UP | eBay
Test Slow
