alright tigger73 i'll write up something just for you lol here is the aftermarket trims i got from china. full window trim, door trim and back trims. shipped via express DHL the whole thing cost around $160 AUS including shipping. i also have scuff plates and pedals added too but i wont bother posting those.
you will need isopropyl alcohol spray, clean cloth and red double sided 3m tape. first clean the application parts with the alcohol spray and wipe it clean. i found some parts that didnt fit 100% so the chrome strips might be rather loose because the backing tape is not touching the surface or pulling away from the surface. in that case just apply extra 3m tape to thicken up the layer so both surfaces are touching evenly. if you do it right, you wont be able to pull the trims off unless you rip the whole thing off which will bend your trim pieces....the tape is that strong. i had to alter the strips for the passenger window since its longer. other then that its pretty straight forward.
