Good day all
Not sure about other 2012 Tiguan owners or other new VW models but I did not have this function till yesterday
Plug your VCDS cable in and access module 17 instruments
Enter the UDS Adaption 10 menu
Select the channel with the label "Volume to be replenished"
Change the stored value from "no" to "yes" and then select "do it" to save the setting and exit VCDS
You should now have an extra option in the MFD settings called refuel
A value will then be displayed once 10 liters of fuel has been consumed from a full tank that will be required to safely refuel the tank to full again.
Not sure if this will work with 2011 models but maybe a few 2011 owners can have a crack at and let the forum readers know. I do know from my research on attempting to activate the driver alert system there is suttle differences in the coding between the BCM module 9 and this module with older 2011 models
BTW I am still looking for an Autoscan of a 155 Tiguan please!
