Hello,
I am looking at changing the Haldex coupling high performance oil and read that you need to check the temperature post oil change.
Looking for some assistance with the VCDS application to see whether it can tell me if I can get the temperature from the application. So far I have used VCDS>Section 22:AWD>MEAS. BLOCKs> and been through all 250 configus (some are blank as per manual) but have not come across an option showing me the temperature - any ideas of how I can get the temperature from VCDS, if I can?
Many thanks,
Andrew.
Many thanks,
Andrew.
All good again once I filled it up. That was at least 25000km ago and haven't had any dramas since so pretty robust set up I'd presume.
