Front Sway Bar + ALK installed in Tiguan
  • #16
    Originally posted by HaywireTig View Post
    Good to see here too Matt. Yea I've got the H&R springs too and they were pretty good. I'm just greedy and want to flatten the ride more around corners. Hence I've got the ALK. But I haven't fitted it yet. Just thinking if I shd add ALK to front or rear sway bar. I've got the rear strut bar that was custom fabricated from a mate overseas. But want something more..... Lol....
    The ALK does make the steering feel quite a bit heavier, though turn-in is a lot sharper. This is quite noticeable but you do get used to it.
    And as it's name says the Anti-Lift Kit does greatly reduce the nose lifting under acceleration and dipping under brakes. The ALK won't stop the body roll around corners - you'll need the sway bar for that.
    If I was to put a number on it I'd say the heavy duty rear sway bar improves body roll by 80% and front sway bar by 20%.
    I am actually surprised my wife didn't complain when I put the ALK on - seems as if as long as the radio works and the doof doof comes out the speakers everything is OK.
    Just waiting for the response when the lowering springs go in.... I think she's worried she's going to drop down to pleb level in the traffic
    - Tigger73's 125TSI Build
    • #17
      Hi guys. Just wanted to check how much does Pedders charge for installing the rear sway bar in the Tiguan. He can't seem to give me a figure over the phone. Thanks.
      Sent from my SM-N9005 using Tapatalk
      • #18
        Rear sway bar install should take less than 30mnts max. I would not pay more than $100. (My previous mechanic charged me $30 to fit a rsb to my mk6 gti for his time).
        Diy is pretty easy, but it depends if u r comfortable with rsb install diy.
        Sent from my GT-I9300T using Tapatalk
        MINI Cooper S Clubman - FWD
        • #19
          +1. 30minute job in a workshop with a hoist. 6 bolts to undo replace stock bar with upgraded bar and redo 6 bolts.
          • #20
            Hmm. What do you think is the best rear sway to go for Whiteline? and 24mm or 22mm?
            MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
            MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
            • #21
              Thanks very much for that! He doesn't sound confident saying he's never done one before in a Tiguan. Seems pretty straight forward.
              • #22
                If you're just doing the rear I would consider the 22. If you were doing both I'd go the 24 front and back.
                That's just my gut feel and based on having the 24 on the back of mine with the stock sway bar on the front. I think in this configuration the back is stiffer than the front.
                You probably want to have it the other way around with front stiffer or at least balanced. That's my thoughts.
                Also I wouldn't bother changing the front sway bar unless you were running it on the track.
                • #23
                  Yea. Reading everyone's comments in the past and now yours as well, that the front stock bar is pretty good for general every day use, I'm thinking of changing the rear to the 22mm one too. Good to heat you've confirmed my thoughts and that helps my decision making. I want it balanced... And yes, if anything I'd prefer the front a tiny bit stiffer. But I'll leave the front stock...
                  Will call Pedders on Monday. Only thing is they would need to order one in as none of their other branches had any RSB in stock. $35 extra for freight...
                  • #24
                    Should have asked this before. How much would pedders charge for installing the WALK?
                    • #25
                      Best to ask your local guy. It's not a big job up on the hoist and 3 bolts each side. I'm not sure I would go Whiteline as the housing doesn't bolt up fantastically. I know Tiggy1 used some push on bushings with the stock housings. If I was to do it again I'd probably go this way but then you do end up destroying your stock bushing getting it out. So I guess it's line-ball if you intend reverting back to stock after - probably Whiteline is better in this case.
                      • #26
                        Thanks for that. I'll speak with the local pedders guy later and see how that pans out.
                        • #27
                          Sorry Tig!
                          I seem to have asked the exact same question in your other thread. My bad.
                          • #28
                            Originally posted by alexc2005 View Post
                            Sorry Tig!
                            No problem. Looks like you found the info. Was just going to refer you to this thread anyway
                            So yes probably suggest the 22mm if you're just doing the rears but that's only my suggestion. I don't think the cost is that much different between 22 and 24mm sway bars. Will have to look again but there's possibly adjustable settings???
                            • #29
                              Both have adjustable settings and cost difference is only like 10-15bucks retail. GSL Rally has a promo now ending tonight selling these for just over 200 with the price difference between the two only a few bucks. But I want a more balanced feel so I'm putting the 22mm.
                              Apparently Whiteline is moving their production from Korean to Florida USA.
                              • #30
                                Yep GSL is the way to go... and support a forum sponsor
