Hi guys, help needed as i did a scan and found a couple of faults, can anyone help??
02873 - Control Module for Back-Up Camera (J772)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 3
Reset counter: 164
Mileage: 34608 km
Time Indication: 0
Address 01: Engine (CAW) Labels: 06J-906-026-CAW.clb
Part No SW: 06J 906 026 AB HW: 06J 906 026 D
Component: MED17.5 4304
Revision: A7H18--- Serial number:
Coding: 04230003190F0160
Shop #: WSC 01324 020 00200
VCID: 6AD0DF1A45A11A489F8
1 Fault Found:
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 4
Mileage: 34598 km
Time Indication: 0
Date: 2096.14.03
Time: 13:47:47
Freeze Frame:
RPM: 3244 /min
Load: 83.1 %
Speed: 55.0 km/h
Temperature: 97.0°C
Temperature: 51.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.589 V
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 B HW: 5K0 937 084 B
Component: BCM PQ35 B 011 0029
Revision: BA011001
Coding: 40180A3B902518C0400800803400002441513088536D8D605C 8000000000
VCID: 3162087668F7A9909E2
Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 21031 012 0203
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 280310 05 54 0403
Coding: 03304D
2 Faults Found:
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 130
Mileage: 32283 km
Time Indication: 0
Date: 2029.14.18
Time: 00:00:04
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
OFF
OFF
OFF
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5N0 920 871 A HW: 5N0 920 871 A
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 110D00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 2F660E0E76C3BF60886
1 Fault Found:
12716032 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 254
Reset counter: 124
Mileage: 33468 km
Date: 2030.14.27
Time: 23:06:11
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 164
Mileage: 34608 km
Time Indication: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 34598 km
Time Indication: 0
Date: 2096.14.03
Time: 13:47:47
Freeze Frame:
RPM: 3244 /min
Load: 83.1 %
Speed: 55.0 km/h
Temperature: 97.0°C
Temperature: 51.0°C
Voltage: 13.589 V
Revision: BA011001
Coding: 009795
Coding: 03304D
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 130
Mileage: 32283 km
Time Indication: 0
Date: 2029.14.18
Time: 00:00:04
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
OFF
OFF
OFF
Coding: 110D00
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 124
Mileage: 33468 km
Date: 2030.14.27
Time: 23:06:11
