Morning all
A couple of quick questions for all the current model Tiguan owners. Mine is a late 2011 132TSI
Tyre wear - how many of you are finding your front tyres are quite feathered on both the inner and outer edges of your tyres? I dont race the car nor throw it around lots, but i have found my tyres are quite badly feathered on both sides after only 6000klms. I am running 36psi in them. Its got Pirelli P6's on it
Auto wipers - the recent Sydney rain has shown me just how bad they are. Set on what i would call the most sensitive setting (ie wipe when the windscreen gets ildly wet) they tend to work quite erratically. I understand they operate off a sensor which relies on water outside the sensor, but i find a lot of the time they will either go off when the windscreen is basically dry or they wont go off at all and i have to manually turn them on. Has anyone else experienced this?
rear wiper - can the wiping function when putting the car in reverse be disabled when the wipers are in the auto mode? I park my car quite often half under cover and there is nothing worse than hearing the rear wiper go off because the front windscreen is wet. I know i can switch the auto wipers off at the stalk but i believe i shouldnt have to. I also know it is operated off the front sensor, which in my case is wet, but i am hoping i can disable this function through VAGCOM.
Windscreen condition - First thing to note is the suction cup marks on the windscreen which you cannot get rid of. Does everyone have these? Has anyone been able to get rid of them? This will be brought up at the first service and i will be demanding it gets fixed. I dont care if they have to replace the windscreen. I should be a bit clearer with this one and note these are not from a GPS carrier, these are from when the factory has fitted the windscreen.
My windscreen, when wet, is absolutely filthy on the outside and has the wiper marks that i have only ever come to expect from cars with over 100,000klms. Does anyone know how to get rid of it? I have tried a clay bar, autoglym, wax, brake clean, nothing will clean it off. Its quite annoying as when driving at night it makes it quite hard to see out of and in actual fact quite dangerous. I dont believe VWA will do anything about this but given i havent even topped up the washer bottle and its still running the windscreen additive they provide form the factory i think its unacceptable. The wiper blades are also the factory fitted ones.
Any adivce or feedback would be great.
