Hi all
Has anybody managed to remove the above mentioned part. I have bought a chrome one and tried this morning to remove the original one. Removed the side panel and removed 3 torx screws there and another 3 from the lower facia panel around the fuse box and one immediately below the instrument binnacle in an attempt to remove the panel in which the switch is mounted. Also removed the air duct incase there was a screw there holding it but there was nothing.
It appears there is a screw directly behind the switch holding the panel to the body which means the switch may come out from the front, tried rotating it anti clockwise as new switch has 2 spring loaded extruding pins that push inwards when rotated in one direction. Too scared to use brute force incase I break something. Any advice would be greatly appreciated
