As it is the dimpled plastics they have to be sanded back to smooth before painting so it ends up using a lot of man hours and i have been advised it isn't worth the coin.
So they couldnt spray the dimpled effect properly?
Would it peel?
What if they used a flexible primer?
I believe because of the dimples the paint won't be the same thickness and it will cause problems so it has to be sanded smooth.
Also, the plastic bumpers are a different material to the rest of the car so the paint may look a different shade as a few of the Jetta's up here did theirs and you could see a slight difference.
Might be best to ask a panel shop though.
Yep, will do.
Thanks for the feedback team_v!
2018 Ralyee Green RS wagon. Fully optioned.
Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
Sanding should be your main problem, as long as it's primed properly there shouldn't be a colour difference. I had a colour coded plastic lip on my Golf and there is no difference in colour. If you find a decent body shop though you could get it done for a reasonable price. Too bad you aren't in Brisbane, I had an entire one piece aftermarket fiberglass rear bumper for my Golf that came straight from the factory unsanded and not ready to paint, the body shop I went to sanded it, filled shallow crevices that spanned across the whole thing (it was literally straight out of the factory, no prep work done), and then primed and painted it all for $220.
I have also looked at color coding my Tig in Melbourne. If anyone in Melbourne knows any good paint body shop who could do this without costing an arm and a leg, wld be great.
