Hi mate,
great minds think alike - am going to strip everything out that's not nailed down before I take it to them next week. I suspect one of the rattles (from RH rear door area) could be from the plastic guard under the body, or the plastic lines that run down to the fuel tank under this. Might have a bit of a sticky first to rule that one out. I have noticed similar noise to what you could be talking about and suspect that one could be driveline shunting (the DSG makes some odd noises at times too), but the main one I want checked out only occurs at very low speed over high frequency bumps and appears to come from the front steering or suspension. Almost as if there is movement in the rack until hydraulic pressure builds up or something. Definitley more noticeable now that I have urethane Superpro lower control arm bushes too - possible because less give than the original rubber ones. What's to bet they blame it either on them or the Eibach Pro-Kit springs (even though they were "professionally" fitted by Fulcrum).
Will let you know the result.
