How hard is it to install OEM towbar yourself minus wiring
  • How hard is it to install OEM towbar yourself minus wiring
    Hi,
    Just wondering how hard it is to install an OEM towbar without the wiring. Is it just a matter of taking the rear bumper off and bolting the thing on ?
    I need a towbar for a bike rack and don't want to pay the $1400 for the full dealer install. I can get second hand geniune one for $280 so it seems to make more sense for my use.
    Thanks
    HD
    Search the forum, we had this discussion some time ago. Look in the stickies too.
      What year model is it? MY09-onwards were pre-wired to an extent. Early Tiguans were an interior strip-out job.
      The dealership will still need to take the rear bumper off again to to run the wiring from inside the car to the towbar itself.
      FYI, refuse to pay for more than 4 hours labour
      PM me if you've got any further questions. I may have fitted a few dozen or so.
        If you only want it for a bike rake get the bolt-on towbar that you can get from the USA. Ends up costing way less and should be good for most MY11 + cars, you need to cut your bumper and check it can receive it though.
        Do note that the USA OEM towbars (and eTrailer one) have 1 1/4" receivers and not the more popular Aussie 2" receivers. Limits your choice of towball mounts
        Tiguan My11 125TSI DSG
        Buyii - Daily Deals all on one page
          I fitted the towbar to my Tig with the help of Alex_g from this forum and it was VERY easy. If you PM me with your email address I will email you a PDF of the instructions on how to do it. In a nutshell, I think it was a case of removing the rear lights (VERY easy), remove bumper (most difficult part of this was being forceful enough to unclip the clips, unbolt and remove cross bar, insert towabar and torque up bolts, then re-fit bumper. I have reverse sensors so was concerned about that but there is more than enough extra cable on the one side to allow you to safely remove the bumper.
          As someone else mentioned, if you have a newer Tiguan you may just need to get the bolt on reciever. It's easy enough to check - just get under the rear bumper and cut away the marked out piece of plastic where the reciever goes - if there are 4 bolt holes you can just get the cheap reciever piece and bolt that on.
          Don't be put off doing this. If you get a mate to help you the job will take an hour tops to complete.
          Tiguan TDI, 6spd Tiptronic Auto
          Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
          Avg 7.63L/100km over 189,000kms
            You can leave the tail lights in.
            Also, there's a connector in the right side storage pocket, that you unplug to disconnect the reverse sensors from the car.
            As far as I know, all non-genuine towbars for the Tiguan aren't ADR-compliant. This includes the factory-fitted one that some cars have.
              I would be very keen to find out exactly what the cheap bolt on receiver is and where to get one. Thanks
                Hi All,
                Thanks for all the useful info. Will update this post if I decide to DIY.
                  Hi, does anyone have any info on the prewire?
                  MY12 Tiguan 132TSI + DSG
                    They're pre-wired to an extent. You'll till need to purchase the wiring kit for the control module and rear section of wiring, plus the plug and adaptor harness.
                      Does anyone have the part numbers for the wiring and module required for a 2012 Tiguan?
                      I want to install one so I can carry bikes and possibly skis as well.
                      Thanks,
                      Michael.
                        Thanks,
                        Michael.
                        I just did the DIY install today bought it off a nice fellow on this forum. I did it all by myself under 2 hours.
                        For those we wanted to install the cheap receiver, i have a spare cross bar laying around with the 4 bolts point on it in case you have a earlier model.
                        now i need to know what is the part number to get the "rear part" of the wiring loom. I already bought a used controller on ebay.
                          This is the existing cross bar that came off the car with the 4 bolts on late model AUS Tiguan. Interestingly it has the mounting point for the euro standard round trailer electronical connection.
