G-8VXWWTRHPN Coolant - VWWatercooled Australia
Coolant
  • Coolant
    Does anyone know where you can the coolant for Tiggy from (other than the dealer). I got this from another thread so I'm assuming the price is from VW, but would be interested if anyone knows where else you can get the specified coolant from. Apologies if this has been covered in another thread. I did look in the care sheet info thread but couldn't see it in there.
    Coolant G12 Plus Plus
    VW $20-$25 for 1.5L Concentrate
    Other than from the dealer would be from your dealer.
    Reason for that is, because it's cheap. It's 1.5L not 1L and it is a concentrate, it will make 3L when diluted 50:50 and use only distilled or demineralized water (very important). For once only top up when you need only small amount (200ml), use distilled water. But next top up if needed should be concentrate or correct mixture.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      Thanks.
      Just got the warning light come on with low coolant level indicator. So should I just whack in some distalled water to the coolant reservoir and then just wait until the 30,000k service (which is only 1,000ks away)?
        Probably the fastest solutions, let them check the coolant concentration, as it looks to me that the factory fill is 40% ratio. I'd like to keep it between 50%-60% (no more, the coolant will boil at less than100deg.C if it gets to over65%).
          Sorry to dig up an old thread... I just bought a bottle of G12 plus plus... and i'm just wondering if I need to dilute it... I'm getting mixed messages, I bought the bottle from Audi, and I walked past a service looking guy and asked him if I need to dilute it, and he said no... but from what i've read most people say yes, you need to dilute it... if so ratio %?
            It should be shown on the bottle whether it needs diluting or not.
            Do you get the concentrate or ready-mix?
            Can you give us a part number? Has 9 characters and starts with the letter G...
              The part number is G012A8GM1 G12 plus plus
              It does have instructions on the back but in German... the photo indicates only places with minus celcius...
                It is concentrate, mix it 1:1 with distilled water (do not use tap water, bore or rain water!).
                  Thanks.
                  You've bought 1.5 litres of concentrate, so you need to dilute it with demineralised water (you can buy it from any car parts retailer).
                  The minimum coolant concentration needs to be at least 40% (protects down to -25°C). Otherwise the corrosion, scaling and rust inhibitors won't be able to do their jobs properly.
                  A concentration of 50% protects down to -35°C.
                  The maximum concentration should be 60% (protects down to -40°C). Going over this will impair both frost and cooling capabilities of the coolant.
                  I'd recommend a concentration of between 40% - 50%.
                    Thanks transporter... but where do you get distilled water... bottled water in Sydney aren't "distilled" it's just purified... is that ok? or do I have to use "distilled" water from say the laundry section?
                    thanks
                      Yes distilled or demineralised water from the supermarket. No purified water unless you know that it is H2O ONLY.
                      Sent from my GT-N7000 using Tapatalk 2
                        Thanks guys, did the job tonight, the warning sign disappeared... didn't realise the coolant tank is so small... made a mixture 50:50 2litres and only used half lol
                          Hey John!
                          Make sure you only fill to the high mark with a cold engine! How long since it was topped up? ie how fast is the coolant level dropping? The level on mine is dropping also, tho at a very slow rate. I would guess at about 250ml over the last 10000k's.
