RNS510 Sat Nav not recognising steering controls
  • RNS510 Sat Nav not recognising steering controls
    Hi guys,
    my 125TSI has had a couple of hiccups recently with the RNS510 Sat Nav ...when the car was turned off, radio stayed on and would not turn off. After a couple of tries, it turned off.
    A couple of weeks later it happened again. Also, the only steering wheel control that worked was the volume. On the touch screen I couldn't change stations or select Nav or change radio stations.
    Went to dealer while it was happening and they fixed it by doing "a hard drive reset that was done through our laptop which allows us direct access to the audio unit". They don't know what caused it and asked me to keep an eye on it.
    Anyone else with RNS510 experienced this or have any ideas? ....Letig
    Originally posted by letig View Post
    Hi guys,
    Sounds like the car wasn't coded properly for the RNS510.
    When i installed mine the volume controlls worked but not the selection buttons.
    I had to get the car re-coded to recognise the RNS system by the guys at Harding Performance.
    Never had the stereo not turn off with the car though.
      I had a very similar problem with our one in the Tiguan. The only way was to disconnect the battery for a few secs then after that would be ok for a few months. Dealer said it was a firmware update but just before upgrading they checked the error code and now they have ordered a new one from Singapore.
      R36 Biscay Blue 2008 - Sprint Booster, Supersprint Exhaust. - SOLD
      Tiguan 147 Biscay Blue 2010 - APR Stage 1
        thanks Jasspa,
        what is it they've ordered? Is it a replacement RNS510? If you can tell me what they said they found I could use it when/if it happens again. Thinking I should just push for a replacement now...?
          Yes they replaced the whole sat nav.
            should recode in RNS510 to enable BAP
            Tiguan 125TSI DSG7 naked version with RVC ,BT9w7 ,OPS ,PLA1.5 ,RNS510 ,150W AC-POWER ,FOG light,LED DRL installed at home
            Multivan comfortline 2.TDI DSG7 with RVC BT9w7 ,OPS,RNS510
