Trickle charger
  • Trickle charger
    hey folks,
    i for years have had trickle chargers on my motorcycles and i leave my tig for up to 4-5 days at a time, Im wondering can you use any of the 12v outlets to place a trickle charger on, or does the computer think some strange thing is happening?
    Also on that point of Flat batteries, as the tig has no key entry how do you get into a locked car with a flat battery??
    regards
    Phil
    Skoda Yeti 103TDI-DSG My 13,
    regards
    Phil
    You're about the 10th person I've seen make that mistake. I could just be rude and say "if all else fails read the instructions" but cos it's Friday I'll take it easy on you:
    There IS a key hole BUT it's covered with a little clip on cover at the end of the door handle. Open the cover and use the key OK
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
      hey folks,
      regards
      Phil
      And as for the trickle charger I would recommend CTEK, it comes with the connector that you can connect to the battery and you can just plug the connector from CTEK to charge and maintain your battery.
      MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
      Performance Tunes from $850
      Wrecking RS OCTAVIA 2 Link
        key
        Thanks Derek,
        after i wrote that i thought its probably in the owners manual,
        i appreciate you being gentle,
        regards
        Phil
