Transmission issue
  • Transmission issue
    Hi Guys
    I replaced radiator support which require transmission hose disconnected from trans cooler. It is 6 speed auto not dsg. I put it back everything and did 1km test drive and found that upper transmission cooler hose disconnected after 100m driving and lost all the fluid. Now it does change the gear. There is no error or anything on dashboard. What are the chances that transmission is still good after refilling oil. I am planning to refill with oil pump, does it require special tool to fill or just insert hose and fill it.
    Refill transmission oil and working fine.
