auto hold
  • auto hold
    has anyone been using the auto hold feature in a Tiguan?
    there's seem to a soft high pitch sound when I turn on my "auto hold". it can be heard when the it is in use of course (idling or stopping at lights).
    anyone experiencing the same issue?
    Silver Tiguan
    Basic Rocks
    Probably the motor that drives the handbrake mechanism. I don't really use auto hold but I'll check next time I do. Is it the same sound as when you turn the hand brake on manually?
    Forever blowing bubbles.
      It would be the motor pulling on the handbrake that you hear, though I am surprised you can hear it above the idle.
      Its a clever mechanism, though pointless in an auto. In fact, it made take off a little jerky when I've played with it.
      I assume it will become more relevant as a roll precaution when idle-stop versions are released (my guess - no insider info here)
      EDIT: no motor - refer below, still some tricks the Tiguan is revealing
      TDI tiguan in the drive. ParkAssist, comfort, fogs
      Service every 15,000, new fault code every 7,500km
        HAte to say it guys BUT the handbrake isn't activated with the auto-hold, it's all done with the ABS. If you try you'll notice that you don't get the rear "jacking" and releasing as you would with the handbrake. All that happens is that when you've stopped the ABS "holds" the brake setting as it is. So, not sure what you can hear (I don't hear a sound using auto-hold in mine) but it isn't the handbrake motor.
        Derek
        Alexandra
        2022 R-Line Golf Mk8 in Kings Red Metallic
        Previously 3 Tiguans 2008, 2013, 2017
          Derek's right, it's the ABS that holds the wheels, that's why some people complain about the creaking sound (seems that the brakes hold at the pressure you applied when you pulled up, so if you didn't push down hard enough, the brakes may not quite be holding - or only just). Mine makes a small noise as I pull up and then when I take off and the brakes are released.
          Maybe try pushing your foot down harder when you pull up and stop - then see what happens.
            Good info Derek, I just assumed it worked on the hand brake, I think i've only used it once to make sure it worked
              I use it all the time, makes for quicker getaways
                Can't say I've heard any noise of mine.
                I use it quite regularly in traffic... and it is great!
                2009 147TSI Tiguan, Deep Black Pearl Effect, Black Leather, Sunroof, RNS510, Bluetooth, and MDI.
                Delivered 22 May 2009
                  am i correct that you have to turn the auto-hold on each time you get in the car, if so do you think there would be any drawback in being able to have it on all the time?
                    Yes you have to engage it every time you turn the car on.
                    Is a shame there is no default ON
                      You'll probably find you can code it to come on by default with VAGCOM. You can on the Passats, and that's the same coding system as the Golf, which I think the Tiggy shares too?
                        looks like it can be done with VAGCOM looking at ross-techs website
                          I have VAGCOM if anyone in Brisbane wants it coded. You'll need to find out what to code... are there instructions on Ross Tech's site about what to change?
                            no idea sorry there is some info here some here http://wiki.ross-tech.com/index.php/VW_Tiguan_(5N) but nothing really to activate it
                              I had that soft high pitch sound when I turn on Auto Hold as well, but I have to turn the volume right down to hear it.
                              As I was having some issues with my gearbox, I just brought my car back to the dealer for them to have a look. While I was there, I got the mechanic (probably still an apprentice) to listen to it and he was saying its comes from electronics that was being activated. He said he has never heard it in a Tiguan before but its a common problem in the Polos.
                              I was thinking does Polo have Auto Hold? They have Hill-Start Assist which probably has the same working mechanism???
                              125TSI | Mountain Grey | 6SP Automatic | Leather | RNS510 | Rear View Camera | Comfort Package
