Antenna
  • Antenna
    Hi all,
    Has anyone replaced the stock standard antenna on the Tig? I believe if you have RCD310 and RCD510 the antenna is the same i.e. a very long one. But with the RNS510 you get the antenna that looks a little bit like a shark fin. The existing antenna is too long for my liking and I fear that I might snap it off one day when I use my cross bars to carry stuff on the roof.
    I asked Volkswagen and the only other option I have is the shark fin one that is being used when you have the RNS510. But they aren't sure whether it would work with the RCD310. Alternatively is to look for an after-market one. Has anyone replaced their antenna before?
    I got the Sharan replica antenna for mine as the stock one was hitting the rolladoor, you can get em here, good service and free shipping on this item too Screws straight in no mods required.
    Forever blowing bubbles.
      http://www.dubaddiction.com.au/index...products_id=21
      Thanks Pullstarter. I saw this but I wasn't sure whether it would fit the Tigga as it looked it was for the Golf.
      How do you fine the reception? Any problems?
        No difference in reception to the stock one that i've noticed. Maybe middle of nowhere would be different but I usually listen to CDs on a trip anyway
          Pic of antenna installed
            That is great. Thanks for the link and photo. This will save grief in some of my local car parks.
              I want a shark fin on mine!
              Can anyone confirm if you get the RNS510 installed at a dealer that they will put a shark fin on it as well?
              (I currently have the RCD510)
              2009 147TSI Tiguan, Deep Black Pearl Effect, Black Leather, Sunroof, RNS510, Bluetooth, and MDI.
              Delivered 22 May 2009
                The shark fin costs about $250 but I think you need to have the shark fin installed anyway if you upgrade to the RNS510 but I might be wrong. Give your local dealer a call. Ask for spare parts/service.
                  I got this one as it's pretty neat, I haven't loss any reception and as Pullstarter when I'm on the highway I'm normally on CD or IPOD
                  http://www.ecstuning.com/Volkswagen-...tml?imgID=3482
                    Pullstarter,
                    How easy is to install this? can I do it myself.
                    Thanks.
                      Originally posted by varsur View Post
                      Pullstarter,
                      Thanks.
                      I've got a different one (looks exactly like the original BUT shorter) and they're totally SIMPLE to install, screw one out, screw the other in, 30 seconds !!
                      Derek
                      Alexandra
                      2022 R-Line Golf Mk8 in Kings Red Metallic
                      Previously 3 Tiguans 2008, 2013, 2017
                        I'm pretty sure that the shark-fin is NOT required for the RNS510 cos it's actually for satellite radio or something like that. If you go onto http://www.mytiguan.com/ you should be able to find a thread from Rocc in Jamaica who retro-fitted the RNS510 in his Tig and I'm almost positive he just has the standard antenna cos the GPS one fits inside the dash somewhere.
                        Derek
                        Alexandra
                          Pullstarter,
                          Thanks.
                          As NZ says, unscrew original, screw on new one, simple as that You don't need to change the actual base just the screw in part on top of the base.
                            Antenna or Aerial in the UK
                            Mine wouldnt go under the garage door so I just removed it. The radio and sat-nav still works OK.
                            I just screwed in a short bolt to fill the hole.
                              I had the same probelem with the garage door that's why I went the stubby. Being in the UK you can get them fairly cheaply on Ebay, there's hundreds on there to choose from.
