For you "tweakers" out there, I came across this useful thread on VWvortex Forums on Tig VAGCOM tweaks:
Tig VAGCOM tweaks
The dip-side-mirror-when-reversing tweak might be useful.
I don't have off-road tech (the moving compass in the MFD annoyed me too much) but I would like to have the low pressure tyre warning.
Apparently it determines this through the ABS/stability control system by comparing rolling diameters of the tyres. So its only a bit of software to be enabled - no hardware. Now if someone could find the bit to enable this feature, THAT would be something.TDI tiguan in the drive. ParkAssist, comfort, fogs
Service every 15,000, new fault code every 7,500km
The dipping mirror only works if you have the electric folding mirrors I believe. The moving compass you refer to doesn't move at all, just has a N or NW or whatever shown in the top of the mfd. The low pressure warning is a function of the ABS but I doubt you could activate it without the "switch" which is used fro resetting / clearing it.Originally posted by Sanman View PostThe dip-side-mirror-when-reversing tweak might be useful.
CheersDerek
Alexandra
2022 R-Line Golf Mk8 in Kings Red Metallic
Previously 3 Tiguans 2008, 2013, 2017
