Hoping someone can help when we first picked up the Tig when you held the unlock button down on the key fob for a few seconds it also powered down all the windows. some how when i was setting up the other features this one has stopped working. have followed the handbook to set it back up and havendone a full system reset, but still no luck!! can anyone shed some light on this for me please
All windows go down
Have you tried both sets of keys.Originally posted by miko View PostHoping someone can help when we first picked up the Tig when you held the unlock button down on the key fob for a few seconds it also powered down all the windows. some how when i was setting up the other features this one has stopped working. have followed the handbook to set it back up and havendone a full system reset, but still no luck!! can anyone shed some light on this for me please
I have one set that will and the other that will not open the windows,
I was under the impression you had to get the dealer to change the functions.
It should be in the "Comfort" settings of the MFD...if all else fails..go back and see the dealer. They will know, and should be able to explain it to you.MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
No comfort settings in my MFD there is a convenience but no comfort...
when i press and hold the unlock button the indicators do a secondery flash a few seconds later then nothing am assuming the windows would go up/down then?
will drop past dealership on monday and see if those muppets can sort it out
Sorry...you are correct...Convenience...not Comfort
Glad to hear you got it fixed. Hope it stays that way.Originally posted by miko View Postgot it all fixed up today at the dealership, aparently the Keys lost the codes, or fell out of sync with the car????
took about 30-45 minutes to fix
Would be interested to hear if it happens again - or if there are others out there that come up with the same issue?
Now I hear the reason for your problem, I think the same sort of thing happened to us with our Golf a while ago. Panel shop had to fix the front door and quarter panel after a ding and they screwed up the locks and windows. We had to go back twice and finally get them to take it to VW dealer to fix the key coding to the car.
Originally posted by miko View Postgot it all fixed up today at the dealership, aparently the Keys lost the codes, or fell out of sync with the car????A minor clarification if I mayOriginally posted by TonyTA View PostPanel shop had to fix the front door and quarter panel after a ding and they screwed up the locks and windows. We had to go back twice and finally get them to take it to VW dealer to fix the key coding to the car.
I'm pretty sure you guys are talking about the remote getting out of synch with the car. This seems to be pretty common. The procedure to re-synchronise your remotes is not that difficult and is usually described in your owner's manual if you want to do it yourself (and there are usually various descriptions floating around on the web for free).
The term "Key coding" usually refers to programming the car's ECU to accept the transponder (immobiliser chip or RFID) that is in the key blade half of the unit (the remote is the other half). If this isn't done correctly your engine will start but cut out after a couple of seconds.
This is much more difficult and involved, and can only be done using VCDS or in some cases it is a dealer only job (but you usually only ever have to do it if you get a new key or are replacing the dash instruments).2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
