How fixed fault code 01499 -01495
  • How fixed fault code 01499 -01495
    Hi guys
    anyone of you have got these fault code 01495 and 01499
    I have been getting these code since I change the halogen from light bulbs for Led bulbs .
    So, when I switch on the night light sometime I got these error.
    Thanks in advance for any advice.
    VW Tiguan 2016 S
    You need to turn off the cold bulb diagnostics or get resistor packs to trick the BCM into thinking your bulbs are not out.
    Or you could also switch your globes to "CAN BUS compatible LEDs"
      Ok copy that. So you know how to turn off the cold bulb diagnostics.
      VW Tiguan 2016 S
        What scan tool do you have, VCDS, ODB11 etc? it will depend on your BCM part number on how to turn it off.
          Hi MIG
          I use VCDS but I don’t know the BCM part number.
          I am not and expert with this electronic cars. But I do as much as I can. 😺
          VW Tiguan 2016 S
            This is the products specification 7
            input wattage 36 watts
            operating voltage DC 12-24V
            luminous Flux 3800LM/bulb
            color temp 6000K
            light source custom flip chip
            VW Tiguan 2016 S
              If you do an autoscan with VCDS and post it, we can work out what needs to be done.
                VW Tiguan 2016 S
                  Here are the fault codes with description. I hope they work MiG . See ya ��
                  VW Tiguan 2016 S
