Question. Is there a brushless motor type pump available for a gen 4 Haldex? I see the gen 5 pump is the same model pump. As the motor is such a weak spot I would have thought there may be an alternative.
Haldex pump
Package arrived and I just replaced the haldex pump, filter and oil. Trickery tight space but managed. Easiest to pull the controller to access the pig plug for the pump. Here’s the supplier, UK. Good prices. Home Page - Haldex Parts and ECU Repairs by Auto Fault Finder 01270 440151
Originally posted by Nyyyko View PostQuestion. Is there a brushless motor type pump available for a gen 4 Haldex? I see the gen 5 pump is the same model pump. As the motor is such a weak spot I would have thought there may be an alternative.
Same here. Had to change pump after ~80K.
The weak link isn't the pump, rather oil change interval as the filter gets clogged easily, thereby, burning the pump motor. To prevent this = every 40K change oil + clean filter screen --> every 80K change oil + filter
