Originally posted by jdw
View Post
DSG and how to get the best of it
Originally posted by jdw View PostNo, I have a GTI Performance.
Originally posted by ewok666 View PostGlad to hear that. The GTI, like the R and the S3 runs the DQ250 and it seems the VW engineers are outright to stupid to get the gear selection right. I can confirm that, before my DSG tune, D mode tried to get to 6th gear before I hit 60km/h while S mode held 2nd up to 4000 RPM even without accelerating. I got the tune and it made the problem go away, among other goodies, nut I was also told ( can't confirm) that the 7 speed DQ500 did not have the same issues.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostThe VW engineers aren't stupid. The job number 1 for the DSG is to get the best fuel economy and they've done it well.
Originally posted by ewok666 View PostHow does holding 2nd to 4000 RPM help with that once you put it into sorts mode? Almost everyone I spoke to complained about that.
I found that using the individual setting and configuring the drive mode to sports but DCC to normal works well. I drive it in D most of the time, but having the mode set to sports increases the throttle sensitivity, even in D, so the car feels more responsive, and the DSG does seem to drop down gears easier when input my foot down.
2017 Tiguan 162TSI Highline/R-Line
2017 Audi S3
I've seen this question posted in lots of places and have asked the question myself, particularly in the light of the Ford fiasco where the driver gets blamed.
In a nutshell there is nothing out there that explains how you should drive a double clutch gearbox.
There is lots of information from owners on how to get the most out of one, but nothing from manufacturers (I've found) on what the driver must do.
I find the Jetta gets it right most of the time. Coming down the SE freeway I'll put it in manual and select lower gears to reduce brake applications. Going home there are 2 corners with hard acceleration directly after, for these I slip it into sport. The rest of the time for normal driving the DSG is OK, although it selects the higher gears a little before I would. There again, I picked the Jetta for the broader torque spread of the twin charged motor, courtesy of the supercharger.
I personally do not like manually selecting gears in any automated gearbox. I want the gear change to occur when I move the lever, not when the electronics make the change. If it happens almost simultaneously there is still the disconnect. Maybe its better with paddle shifters, but I doubt it. The electronics still make the change and the driver is disconnected. Personal taste, I know.2015 Jetta Highline
2017 Ducati Supersport S
I have a Mk 5 GTi with over 230k on the clock.
No issues at all, except for the occasional rollback on a hill.
I drive in D all the time, but use paddles when approaching a corner or round about.
After accelerating out of the corners i upchange to 6th and after about 10 sec it will automatically switch back to auto mode.
Perfect for me. I love it.
Sent from my SM-G900I using Tapatalk
Originally posted by jrgti View PostYou can actually double shift up or down provided the revs are in the right range.
I'm hoping my 7spd DSG will have the same "temporary" manual mode as my wife's Q7. Whilst in auto mode, you can tap a paddle to change gears manually, and it will stay in that gear for around 20 seconds or so, with manual mode showing on the dash. Then it relaxes back into auto and recommences changing it's own gears again. Is that the way the current 6 speed works ?2017 - Golf R 7.5 - Blue - DSG - Proper Roof - DAP - Res' delete - Dynaudio delete
2008 - Mazda 2 - (Maybe my first child scared me a bit) -1998 - Wrx (modded up to but not including forged pistons)
1988 - Corolla TwinCam - (couldn't insure a 323 Turbo)
1967 - Tonka Tip Truck - Red with 2 inch plastic rims and a massive sand scoop.
Originally posted by jdw View PostAny thoughts on the Harding Performance DSG tune ? I am seriously thinking about it to get rid of the "race to 6th gear issue" and to make S mode less aggressive ....however at $1,295 its not cheap.
I'm not sure what they charge but I think it would be closer to $750.00.
You can find them on Facebook.2001 Bora 4 Motion Sport now used by number two son
Temporary manual mode?
Thats the way my old Mk V GTi works.
Tap the paddles to down shift, being on the brakes coming into a turn it has preselected the next lower gear, and after accelerating out and changing up you can wait for the dsg to swap back to auto or hold the up (+) paddle and switch off manual mode.
If you look closely at the up paddle it has OFF as well as the + symbol.
I may be a bit late in the thread but here is some interesting well explained 'don'ts' for a dual clutch transmission
MY17 Tiguan 140TDI + DAP; Ruby Red; Notification of Birth 19 May'17; Emigration on Morning Celesta began 2 June'17; Entry into Australia 17 Jul'17; Citizenship obtained 8 Sep'17;
