Hi everyone, I have recently purchased a 2019 Tiguan with the 20 inch stock wheels (from factory). I noticed that when I am driving on the highway @ 100km according to my Google map GPS, my odometer reading is closer to 110km. Does anyone know where I can go on VCDS to adjust the odometer to read closer to the GPS reading? Thanks guys
Odometer Calibration VCDS
Normally there is coding for wheel circumference, but it depends on the model of the cluster, can you post the auto-scan from your cluster?MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Here is the guide for VCDS
Ross-Tech: VCDS Tour - AutoScan
In the file, it creates you should see something like this for your cluster, paste that here and I can check if there are any coding options.
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3C8 920 881 A HW: 3C8 920 881 A
Component: KOMBI H04 1104
Serial number: 00000000000000
Coding: 710F010000
Shop #: WSC 00028 028 00020
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
VCID: 2B5502E7421866D74A-807E
No fault code found.MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Here is what I did as mine was about 5 over actual speed at 100kph
In an OBDELEVEN Go to 17 Dashboard /Long coding Scroll down to Wheel circ Mine was on 1 so I changed it to 3 and it now is dead right at 100kph
I suggest that yours wont be that far out but if it is its still legal but annoying. So try swapping it to 4 and see if it comes right. There are 7 alternative numbers using the OBDELEVEN Higher makes it slower Make sure you test the GPS speed on a flat preferably straight road as changing elevations can give false readings.
You also are using wrong terminology Your SPEEDO is whats incorrect. NOTHING to do with ODOMETER which records distance.
Do you have ver1 AID or ver 2 with the temp and fuel scale on each side Makes a difference as to what you can doLast edited by Guest001; 23-09-2022, 12:07 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
I dont know I have the better V1 but try it and see but write down what you didOriginally posted by Eman View Post@Hillbilly, thanks I will try it . So I have the temp and fuel on either end, what does that limit me too? Will that process still work for me ?2021 Kamiq LE 110 , Moon White, BV cameras F & B
The settings will be under "17 instruments" if they are available, check adaptation channels as well.
Sent from my SM-N960F using TapatalkMY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
I wonder why we bother telling you proven things Especially when they dont know the difference between an odometer and a speedoOriginally posted by Eman View PostI found wheel circumference in 5f Information electronics. Stored value is 0mm and I can input a new value in mm .I assume if I make the size larger than 0 then theoretically it should slow the speedo? What are your thoughts?Last edited by Guest001; 23-09-2022, 05:45 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Good See we do know what we are talking about after all LOLOriginally posted by Eman View PostExcellent news. I went for a drive on the highway and the speedo is reading less than 1km out. This is awesome and thanks again to everyone who responded to getting this fixed. 2021 Kamiq LE 110 , Moon White, BV cameras F & B
