Map Updates
  • Map Updates
    If the map updates happen in the background….how do you tell if they are ‘actually’ happening.
    You wait half an hour and check in your version information. Which of course you did before trying to update and so if it was 20.3 as most are it upgrades to 21.2
    There is already a thread on Tiguan Mib3 map updates so best to stick with that as the info is already in there
      Already threads on this This one for starters Same unit different make Map updates for KAMIQ and SCALA with AMUNDSEN MMI
        Cheers yes I did check the version …as you said 20.3….Thanks for the link I’ll check it out
          Cheers…now saying 21.2
            Well there you go Spend a while reading through the manual as most stuff is in there and easily followed
