Hi everyone,
We've got a 2019 allspace r line and the rear right hand door is having a few dramas...
-when the car is locked the rear right door doesn't lock (sometimes)
-the light on that door stays brighter than the others when we have set them all on a lower light
-the door doesn't open from the outside occasionally unless you try from the inside (child lock is on) you have to pull the handle inside and it somehow resets something so you can open it from the outside.
-the window lock on the drivers door only works intermittently
I had the car back with VW for 2 weeks and they suggested it was a faulty steering rack/pump (or similar) draining power from that circuit 🤷*♂️ they replaced it and it was good for a month or so and now the problem is back.
Has anyone had any of these problems or can give any advice?
