I had the exact same problem with my 2015 BMW X1. The problem ended up being a blocked condensation drainage hose that caused water to build and eventually soak the polled filters causing them to go mouldy and hence that smell you get.
Common trick from Dealers to generate 'work' is to block the condensation drainage hose during a service job
Once they block the hose, the whole system fills with moisture and stays there when the engine is turned off
This creates mold and bacteria that then causes a rank smell that infects the whole AC system
Clearing the drain hose may require some hot days to dry out the system before the smell disapates as well as replacing the cabin filter
Last SUV dealer wanted to charge me a 'flush and cleaning fee' where they would put a 'cleaning' gas through the system. Cost $200
