Originally posted by Sydneykid
View Post
Cut vs. Reset aftermarket lowering springs
I think at the back of my mind I had this hunch as well.Originally posted by Transporter View PostIt’s illegal, don’t do it (just in case you don’t know that).
You’ll also invalidate your insurance.
I suppose I was hoping that resetting the springs was right on the line of what you can get away with. That plus the fact that it’s offered as a professional service. Wilful ignorance on my part perhaps!
How would anyone know that the springs have been reset? The process is to heat them up to a bit over 1000 degrees, which obviously burns off any paint or markings, compress them to the desired height, retemper them, often also shot peen and then paint. So they look like new springs that no one could tell were reset. So whether its illegal or not is a mute point as no one could possibly prove it one way or the other.Originally posted by PDMJO View PostI think at the back of my mind I had this hunch as well.
As for cutting, if the springs are parallel then the only evidence is the lack of paint on the end of one coil, which when installed in the car is invisible as it sits in the spring seat. If you are good with a touch up spray can it's invisible. So whether it's illegal or not is again a mute point.
Insurance wise, that depends on your insurance company and applies to any modification you make. If you are concerned, then keep you standard suspension for a quick swap over before the assessor arrives. If they even bother to, most accident repair approvals are done via pictures these days.
GaryGolf Mk7.5 R, Volvo S60 Polestar, Skyline R32GTST
I see where you’re coming from Gary, but if I go ahead with it, I’ll only be getting the rears reset.Originally posted by Sydneykid View PostHow would anyone know that the springs have been reset? The process is to heat them up to a bit over 1000 degrees, which obviously burns off any paint or markings, compress them to the desired height, retemper them, often also shot peen and then paint. So they look like new springs that no one could tell were reset. So whether its illegal or not is a mute point as no one could possibly prove it one way or the other.
Gary
From memory the springs are black, so apart from the Eibach branding, maybe with some dust on both sets they’ll appear similar.
I'll emphasise something from the first post "if done properly", resetting springs requires the right equipment and an experienced operator to use it. For example, get the temperature even slightly wrong and it will no longer be a "spring", as a result it will sag very quickly. So make sure you use someone suitably equipped and qualified.Originally posted by PDMJO View PostI see where you’re coming from Gary, but if I go ahead with it, I’ll only be getting the rears reset.
