Originally posted by Hillbilly
									View Post
Tiguan Sunroof
 Carsales 162TSi Highline Allspace R pack with Panoramic Sunroof
 This Carsales TSi162 highline has R package with Panoramic Sunroof.
 I haven’t looked into it, but I think the newer models don’t have now. Probably cheaper removing it, than having to use certain parts/practices to make it safe (avoid recalls)Originally posted by Youdotinmymirror View PostSo the ambient lighting works around pano roof now in MY20?
 VW are cheapening as many things as possible lately in their mainstream lineup, it seems. Plastics, struts, buttons all getting worse and/or removed
 Dieselgate must not be fun to pay for.
 You should see the difference between the Golf 7 and Golf 8 for cheapening things.Originally posted by Simonr23 View PostVW are cheapening as many things as possible lately in their mainstream lineup, it seems. Plastics, struts, buttons all getting worse and/or removed Flipper Dog Flipper Dog
 Now - T-Roc R, Audi Q5
 I have the R-Line with pano roof and everyone that gets in the back comments on how light and airy it feels with the sun blind open.Originally posted by Youdotinmymirror View PostWe decided to get the panoramic roof in the end as wife wants a brighter/airy cabin so much so that she wants to opt out of R Line package as it would create a stuffy environment for backseat passengers/kids.
 Yoh wont look back2018 Allspace 162TSI R Line
 We love the sunroof and are so glad that we got it. We have an R-Line and I was worried that the black roof lining might make it really dark, but the sunroof makes the cabin really light and bright. We don't have any issues with heat at all. The vast majority of the time we have the blind open and we do actually open it up a lot (both tilt and also fully open).
 2017 Tiguan 162TSI Highline/R-Line
 2017 Audi S3
 My 162TSI Highline Allspace R-Line has developed a leak which may be due to a faulty panoramic sunroof. I purchased it new in February 2019, it's done 11,500km and was serviced at 12 months.
 Water is pooling in the left rear footwell, some dampness in the front left footwell also, accompanied by a characteristic musty odour (cold wintry Melbourne - this water doesn't want to dry away). Right side footwells are dry as a bone.
 Car has not had much use in the last 6 months and is usually parked outside, level ground and not too many trees about. My previous car had a sunroof and was parked in the same spot for 6 years and never had so much as a drop of ingress - I don't reckon it's a particularly dirty spot. I checked the outlets for all the drainpipes and they were relatively free of muck. I also ran some water into the sunroof drain channel and the water flowed freely from both left outlets, however the rear flow was somewhat less. I was able to dam the flow so that water exited the left rear drain only and a bucket under the rear outlet to compare with the volume going in. I reckon only about half came through. The rear footwell was also noticeably wetter.
 Due to Melbourne's stage 4 lockdown and the roadmap out of it, the next booking I can get with the dealer is not until late October . .
 Any thoughts on an interim treatment to remove the water and smell?
 This happened to me it was the left side and I am in VIC as well. VW had serviced my car the previous week - but they obviously didn’t clean the sunroof drains. I had to remove the boot lining panels and dry the whole car out to get the water out.Originally posted by Anto View PostMy 162TSI Highline Allspace R-Line has developed a leak which may be due to a faulty panoramic sunroof. I purchased it new in February 2019, it's done 11,500km and was serviced at 12 months.
 On my car they were blocked where they drain under the back of the car not at the roof. They have little covers on them to stop spiders crawling into the drains. Some line trimmer filament will do the trick to help unblock it. It’s also possible that one of the drain joiners isn’t connected properly in your car - less likely if it’s new.
 Sent from my iPhone using Tapatalk Pro
 Did you very quickly (immediately) call the dealer and ask ‘what the f$&@‘
 VW charge heaps for services. For the money they MUST demonstrate value and do everything on the list (all dealers should)
 Edit- Getting off my soapbox for a sec. is sunroof drainage part of the service checklist?
 Yes it is on my last service invoiceOriginally posted by Simonr23 View PostDid you very quickly (immediately) call the dealer and ask ‘what the f$&@‘
 Edit- Getting off my soapbox for a sec. is sunroof drainage part of the service checklist?2021 Kamiq LE 110 , Moon White, BV cameras F & B
 Yes, I reported the issue to the dealer when I made the booking. Perhaps unsurprisingly the service centre agent was quick to point out that VW will want to absolve itself of any responsibility in replacing spoiled carpet and sound-proofing as the "requirement to clean the sunroof drains is documented in the owner’s manual" (although I couldn't find a specific reference to that?)Originally posted by Simonr23 View PostDid you very quickly (immediately) call the dealer and ask ‘what the f$&@‘
 The 12 month service report clearly indicates that the drains were cleaned and I have no reason to doubt that. I am keeping an open mind - I'm not in a position to categorically determine what the issue is and trust that the service centre will fairly investigate the problem, manufacturing fault or otherwise. They also said they’d be willing to submit a warranty claim based on that outcome.
 In the meantime I’ll tape up the sunroof as per iDiesel's suggestion and patiently wait for this friggin lockdown to resolve.
