Ceramic Brake Pads
    I had done 10,000 km, new car. Just changed over the pads, no problems. Fronts are super easy to do yourself.
    I've just had the rears changed out. Got some one to do that due to the electric park brake.
    2018 Tiguan 162TSI R
      If you have OBD11 you can run the replace brake liner routine in:
      Brakes1, Basic Settings, Lining Change.
      I replaced Front and Backs today which is quite simple with the right tools and the OBD11
      I ordered my ATE Ceramics from O/S and used the following codes.
      Fronts - LD2764
      Rears - LD7294
      2019 MY19.5 Highline (R-Line, S&V, Sunroof)
      Stage 3 - Etuners Motorsport - 228wkW, TCU Tune
      G Revision IHI IS38, BMS Panel Filter, CTS Turbo Elbow, CTS Downpipe, Dogbone Insert
      Dynamic Light Assist (OBD11), Eibach Pro Kit Suspension
        Ceramic Pad Update
        A few months ago I upgraded our second car to a new Audi S3. As they run the same brake set up as the Tiguan I was planning to replace the front pads with the the same Ate ceramic pads I fitted to the Tiguan.
        While I am pretty happy with the pads on the Tiguan, although they are not as clean as the Akebono pads I had on the Audi's predecessor. This made me change my mind at the last minute and go with a different Ate pad. The pads obviously look identical but have different part numbers.
        The pad I fitted is 13.0470-2617.2 HSY # 3510 07 033C
        The pad fitted to the Tiguan was 13.0470.2764.2 HSY # 2510 07 028C
        The new pad is a lot cleaner than that fitted to the Tiguan, comparable to the Akebono pads. The only down side is it's about $40 dearer. I'm really happy with this pad and would have paid the difference when changing the Tiguans pads if I knew this.
ID:	1851600Click image for larger version
        Photos are after 300 km of city driving.
          GRD, just new (updated) part numbers mate;
          ATE (front pads) – Article Number: 13.0470-2617.2 (CERAMIC) LD2617 / 24738 / 25217
            As stated I've only done 300 km. and if I find things are different as I clock up more k's I'll post, but on what I'm seeing it looks like a different pad material. Wheels are a lot cleaner.
              Where do you get these from? I've looked around Australian resellers and can only locate this article number from overseas (Europe). In Australia, I keep finding part number LD2764 which I'm guessing is not what I want. Can anyone post a link to a recommended online resellers?
              2018 VW Tiguan 162 TSI Sportline
              APR Stage 3 ECU tune, TVS Stage 2+ TCU tune, IS38 Rev F turbo, APR intercooler, APR dump pipe, Racingline intake kit & 034 rear swaybar.
              XForce Varex muffler & controller on the way.
                Harding Performance stock the ATE ceramic pads.
                - Tigger73's 125TSI Build
                  Yes, but their part number is LD2764, not LD2617. Are they the same?
                    Ring Harding Performance. They should be able to confirm correct part # for the Tiguan.
                      Obvious but true Thanks Tigger.
                        HSY also stock both LD2764 and LD2617. Both of these pads will fit a Tiguan. The LD2764 is a bit cheaper but the LD2617 may be cleaner. I need to get some more mileage on these to be really sure, although at this stage it's looking that way.
                        • #27
                          Thanks
