G-8VXWWTRHPN Rear Mudflaps for RLine - VWWatercooled Australia
  • Rear Mudflaps for RLine
    Here is what I did to get rears on my Rline
    I bought some that supposedly fitted off Ebay
    They didnt because the bit that fits over the black plastic wheel surround is to narrow.
    So I carved that piece off and with a heat gun I massaged the outer piece to fit closer against the surround trim and just used two screws to hold them on
    Like this
    Had to cut the pice i 4th pic off and heat the bit in the third one to move it across to match the existing body screw
    They do however look quite neat and sort of factory
    Nice. I’d like mud flaps for my Golf R but I didn’t think they were available at all.
    Ben
    Current: ‘19 VW Golf R
    Past: ‘05 RS 225 Cup
    Ben
    2015 Polo GTI & 2019 Golf R
      Ben
      Dont know about the Golf but they certainly arent for the standard Tiguan so I just improvised
        Awesome job Hillbilly
        Do you have Front Mud Flaps as well for the Tiguan R-line ?
          Yes I have the factory ones that do exist but some parts guys dont know that The part no is the same as standard ones but has an A suffix
          I also have the front ones from the set I bought on Ebay but dont know if they will fit or not
          Pics are of the factory fronts which are $117
            Can you provide me the part number for the Tiguan R-line specific Front Mud Flaps
              Special for you via Google LOL 5NA075111A Here are the instructions even I did mine without taking wheels off as I have a right angle drill chuck and got it in ok
              Make sure you attach each one by the existing screw as shown and adjust them carefully to match each side Then drill the top hole and put plug in to locate it securely then do the others. I am pretty fussy about things being even LOL
              I did most with the wheel on full lock with the rear of it inward and then swapped it to get inner plug in with right angle chuck in behind the wheel.
