I installed a new AGM battery to replace a weak OEM one. Do I need to do any coding since this is different from the original? The battery does not have a BEM sticker with manufacturer and other codes.
Changed to AGM battery, re-coding required?
Under battery adaptation -
serial number - just apply a different number to the old value eg: 1111111111 to 1111111112, that is to reset the history on the new battery
rated battery capacity - make sure your Ah (if different) is updated
battery technology - you should be right with EFB or fleece
battery manufacture - you don't really need if this is not available
Ah and new serial number are the important parts to change.Last edited by Flipper Dog; 17-03-2019, 01:13 PM.Flipper Dog
Now - T-Roc R, Audi Q5
According what i read is "it may varies, you may not have to. If you replace wet-cell type battery to an AGM type battery, or vice versa, you must code for the change. Because AGM and wet-cell batteries require a different rate of charge output from the alternator. Moving between these two types without coding can lead to over-charging or under-charging."Originally posted by pbrowne View PostI installed a new AGM battery to replace a weak OEM one. Do I need to do any coding since this is different from the original? When to replace car battery? Visit this link for more info that you need. The battery does not have a BEM sticker with manufacturer and other codes.
"AGM and other sealed batteries do not like heat and should be installed away from the engine compartment. Manufacturers recommend halting charge if the battery core reaches 49°C (120°F)."
How is that? Where did you put yours?
MY18 VW Tiguan Comfortline
VW stop start vehicles have AGM batteries in the engine bay and work quite well even in QLD Mine lasted 4 years of only occasional use and sitting around for often 2 weeks at a timeOriginally posted by PeteC View Post"AGM and other sealed batteries do not like heat and should be installed away from the engine compartment. Manufacturers recommend halting charge if the battery core reaches 49°C (120°F)."
