G-8VXWWTRHPN Tyre wear on Tiguan 140TDI R 20 inch wheels. - VWWatercooled Australia
  • #31
    Which ones do you have now?
    The Conti’s or the Pirelli’s?
    2018 Allspace 162TSI R Line
    • #32
      Pirelli's
      2017 Tiguan 162TSI Highline/R-Line
      2017 Audi S3
      • #33
        Originally posted by Gladbach View Post
        Pirelli's
        ^^^^^^^ These mine seem to be wearing well but are about $460 each
        • #34
          Yep, I've done almost 50k on them.
          2017 Audi S3
          • #35
            depends how you drive. i've got the conti's and will be able to get 60k comfortably at this rate, but my tiggy is stock, and i drive fairly conservatively.
            • #36
              Michelin Pilot Sport 4
              Flipper Dog
              Now - T-Roc R, Audi Q5
              • #37
                For daily driving I drive fairly conservatively, I open up every now and then with a bit more spirit but that's about it.
                2017 Audi S3
                • #38
                  I'm looking at replacing my tyres soon - the original continental contisports on standard Highline rims.
                  It's about 4000km off 30,000km and I'm not surprised but a little disappointed they are not lasting longer.
                  Has anyone got any tyre brands and models to suggest? I do like the way the ContiSports feel and handle - just wished they lasted longer.
                  VW Tiguan 2018 162TSI Highline
                  VW Polo 2015 81TSI Comfortline
                  • #39
                    A lot of people have had good mileage with the Pirelli Scorpion Verde. Though if pushed you’ll find the limit of the tyre. They’re a comfortable, quiet, higher mileage tyre but you do trade off some grip at the limit.
                    I’m currently running Goodyear F1 Asymmetric 5’s now and performance is improved over Pirelli but still too early to tell how they will wear, however having run the F1A3’s previously I’m expecting 40,000+km or so from the set.
                    - Tigger73's 125TSI Build
                    • #40
                      Is there an official VW document regarding
                      1) How frequent (no of km's) you need to rotate the 20 inch Tyre's on a Tiguan Highline Rline ?
                      2) The rotation sequence (i.e. front to back, diagonal etc) for the 20 inch Tyre's on a Tiguan Highline Rline ?
                      • #41
                        Front to back never diagonal
                        Tyres are usually recommended to rotate at 10,000km intervals
                        • #42
                          It depends on the tread pattern whether you have a directional tyre or asymmetric.
                          The directional tyre will have an arrow marking direction of rotation and can only be fitted on one side. The tread pattern is designed to run one way only. These can only be swapped back to front.
                          The asymmetric tyres can be run either way and allow a 4 wheel rotation. Most tyres these days are asymmetric except for some higher end performance tyres are still directional.
                          • #43
                            If non-directional tyres (eg: assymetric or "standards"):
                            Main drive axle straight back/forward.
                            "lazy" axle to the diagonal opposite.
                            It's like yoga for tyres where if you rotate in one direction, you need to rotate the other way.
                            • #44
                              I must be old school then as way back we were told that radials would run lumpy if made to run "backwards" so have always done mine on same side Got plenty of running so cant be too bad to do it that way
                              • #45
                                The best I can describe it is that the alignment of the "rubber" and the various belts when new is IIIIIIII and on the drive axle they gradually go ////////, so you reverse the rotation with the goal of eventually getting back to IIIIIIIIIII.
                                That's the internal advantage. Externally it can assist in removing feathering or mild saw-toothing.
                                That's the "How can I explain this to my Mum" version.
                                There are many resources out there. Here is one.
                                Tire Rotation: How and Why to Rotate Your Tires | Bridgestone Tires
                                Combine that with "best on rear" and some compromises eventually have to be made.
